Salta al contenuto principale
HP Pavilion 15-eh SSD Replacement
Spencer Day
Spencer Day e 2 altri collaboratori
Ultimo aggiornamento il 30 mag 2023
20 - 30 minuti
Moderato
Guida OEM
Introduzione
Vai al passo 1
Use this guide to replace the SSD in your HP Pavilion 15 Laptop PC.
Note: This procedure was written using a model 15-eg2015od HP 15 Pavilion Laptop PC, but is fully compatible with any HP 15 Pavilion Laptop PC whose model number starts with 15-eg or 15-eh.
Still under warranty? Contact HP to learn your warranty status, receive a repair under warranty if eligible, or for further warranty information.
This laptop has one slot that supports an M.2 2280 SSD.
Before you starting this repair, consider backing up your current drive. If necessary, familiarize yourself with a disk cloning utility so you’ll be ready to transfer your data to the new drive.
This procedure requires removing the battery to disconnect it. Use care to avoid bending, twisting, or puncturing it—a charged lithium-ion battery can be very dangerous if accidentally punctured. If your battery looks puffy or swollen, take extra precautions.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP Pavilion 15-eh SSD Replacement, Prepare your laptop for disassembly: passo 1, immagine 1 di 1
    • Fully shut down your laptop and unplug all cables.
  2. HP Pavilion 15-eh SSD Replacement, Flip your laptop over: passo 2, immagine 1 di 1
    • Flip your laptop over so the rubber feet are facing up.
  3. HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: passo 3, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: passo 3, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement, Expose the back cover screws: passo 3, immagine 3 di 3
    • The ends of the rubber feet cover four back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be lifted up as one piece.
    • Peel up the end of the foot with your fingers just until the hidden screw underneath is exposed—you don't need to fully remove the foot.
  4. HP Pavilion 15-eh SSD Replacement: passo 4, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement: passo 4, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Tesa 61395 Tape
    $5.99
    • Peel up the other ends of the feet to expose the three remaining screws.
    • During reassembly:
    • Press down firmly on the ends of the feet to secure them into their recesses.
    • If the foot adhesive doesn't remain tacky enough to readhere, you can use double-sided tape such as Tesa Tape.
  5. HP Pavilion 15-eh SSD Replacement, Unfasten the back cover: passo 5, immagine 1 di 2 HP Pavilion 15-eh SSD Replacement, Unfasten the back cover: passo 5, immagine 2 di 2
    • Use a Phillips screwdriver to remove the six screws securing the back cover:
    • Four larger 6.6 mm-long black screws
    • Two smaller 4.8 mm-long silver screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  6. HP Pavilion 15-eh SSD Replacement, Release the clips: passo 6, immagine 1 di 2 HP Pavilion 15-eh SSD Replacement, Release the clips: passo 6, immagine 2 di 2
    • Tight plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the left of the right hinge.
    • Pry up with the spudger to release the clips securing the top right corner of the back cover.
  7. HP Pavilion 15-eh SSD Replacement: passo 7, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement: passo 7, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement: passo 7, immagine 3 di 3
    • Insert the flat end of a spudger between the top right corner of the back cover and frame.
    • Slide the spudger down to the bottom right corner to release the clips on the right edge.
  8. HP Pavilion 15-eh SSD Replacement: passo 8, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement: passo 8, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement: passo 8, immagine 3 di 3
    • Insert the flat end of a spudger between the bottom right corner of the back cover and frame.
    • Slide the spudger to the bottom left corner to release the clips.
  9. HP Pavilion 15-eh SSD Replacement: passo 9, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement: passo 9, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement: passo 9, immagine 3 di 3
    • Insert the flat end of a spudger between the bottom left corner of the back cover and frame.
    • Slide the spudger up to the top left corner to release the clips on the left edge.
  10. HP Pavilion 15-eh SSD Replacement: passo 10, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement: passo 10, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement: passo 10, immagine 3 di 3
    • Insert the flat end of a spudger between the top edge of the back cover and frame, just to the right of the left hinge.
    • Slide the spudger towards the right hinge to release the remaining clips.
  11. HP Pavilion 15-eh SSD Replacement, Remove the back cover: passo 11, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement, Remove the back cover: passo 11, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement, Remove the back cover: passo 11, immagine 3 di 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all the clips.
  12. HP Pavilion 15-eh SSD Replacement, Unfasten the battery: passo 12, immagine 1 di 2 HP Pavilion 15-eh SSD Replacement, Unfasten the battery: passo 12, immagine 2 di 2
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the battery.
  13. HP Pavilion 15-eh SSD Replacement, Remove the battery: passo 13, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement, Remove the battery: passo 13, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement, Remove the battery: passo 13, immagine 3 di 3
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  14. HP Pavilion 15-eh SSD Replacement, Remove the SSD screw: passo 14, immagine 1 di 2 HP Pavilion 15-eh SSD Replacement, Remove the SSD screw: passo 14, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 2.5 mm-long screw securing the SSD.
  15. HP Pavilion 15-eh SSD Replacement, Remove the SSD: passo 15, immagine 1 di 3 HP Pavilion 15-eh SSD Replacement, Remove the SSD: passo 15, immagine 2 di 3 HP Pavilion 15-eh SSD Replacement, Remove the SSD: passo 15, immagine 3 di 3
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the SSD by its edges and pull it away from its M.2 board connector to remove it.
    • When removing the SSD, its thermal pad may lift up with it. If this happens, remove it and re-adhere it to its spot on the motherboard for use with a replacement SSD.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
Conclusione
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Altre 4 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
116.095 Reputazione
837 Guide realizzate
iFixit Membro di iFixit
Staff
121 Membri
20.508 Guide realizzate
1Commento della guida
the ssd screw is glued in for my laptop so if the screw wont turn use a hot air gun and not strip the screw like i did
Franklin Hu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 228
Tutti i Tempi: 6,612
