Salta al contenuto principale
Google Pixel 9 Pro Battery Replacement
Cosa ti serve
  1. Google Pixel 9 Pro Battery Replacement, Safety precautions: passo 1, immagine 1 di 1
    • Let your Pixel's battery drain completely (until it dies) before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
  2. Google Pixel 9 Pro Battery Replacement, Adhesive information: passo 2, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Adhesive information: passo 2, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Adhesive information: passo 2, immagine 3 di 3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro Battery Replacement, Apply a suction handle: passo 3, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Apply a suction handle: passo 3, immagine 2 di 2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro Battery Replacement, Insert an opening pick: passo 4, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Insert an opening pick: passo 4, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Insert an opening pick: passo 4, immagine 3 di 3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro Battery Replacement, Separate the rear cover adhesive: passo 5, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Separate the rear cover adhesive: passo 5, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Separate the rear cover adhesive: passo 5, immagine 3 di 3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro Battery Replacement: passo 6, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement: passo 6, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement: passo 6, immagine 3 di 3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro Battery Replacement: passo 7, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement: passo 7, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement: passo 7, immagine 3 di 3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro Battery Replacement, Prop up the rear cover: passo 8, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Prop up the rear cover: passo 8, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Prop up the rear cover: passo 8, immagine 3 di 3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro Battery Replacement, Remove the wireless charging assembly: passo 9, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the wireless charging assembly: passo 9, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    FixMat
    $31.41
    • While the Pixel 9 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
    • Four 5.4 mm‑long screws
    • One 1.5 mm‑long screw
    • This screw is non‑magnetic—you may need to use tweezers to remove it.
  10. Google Pixel 9 Pro Battery Replacement: passo 10, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement: passo 10, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement: passo 10, immagine 3 di 3
    • Be very careful not to damage the spring contacts under the top left edge of the wireless charging assembly.
    • Use tweezers or your fingers to remove the wireless charging assembly.
  11. Google Pixel 9 Pro Battery Replacement, Disconnect the rear cover: passo 11, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the rear cover: passo 11, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the rear cover: passo 11, immagine 3 di 3
    • Insert the tip of an opening pick under the left edge of the rear cover press connector and pry straight up to disconnect it.
  12. Google Pixel 9 Pro Battery Replacement, Remove the rear cover: passo 12, immagine 1 di 1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your rear cover.
  13. Google Pixel 9 Pro Battery Replacement, Remove the cable cover: passo 13, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the cable cover: passo 13, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two screws securing the cable cover:
    • One 2.3 mm‑long screw
    • One 5.4 mm‑long screw
  14. Google Pixel 9 Pro Battery Replacement: passo 14, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement: passo 14, immagine 2 di 2
    • Use tweezers or your fingers to remove the cable cover.
  15. Google Pixel 9 Pro Battery Replacement, Disconnect the battery: passo 15, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the battery: passo 15, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the battery: passo 15, immagine 3 di 3
    • Insert the point of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
  16. Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave cover screw: passo 16, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave cover screw: passo 16, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the mmWave antenna cover.
  17. Google Pixel 9 Pro Battery Replacement, Unclip the 5G mmWave cover: passo 17, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Unclip the 5G mmWave cover: passo 17, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Unclip the 5G mmWave cover: passo 17, immagine 3 di 3
    • Insert the point of a spudger under the clip near the bottom left corner of the mmWave antenna cover and pry up to unclip it.
  18. Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave cover: passo 18, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave cover: passo 18, immagine 2 di 2
    • Gently pull the right edge of the cover towards the bottom of the phone and remove the cover.
    • During reassembly, insert the two tabs on the top corners under their recesses in the frame and push the cover down to clip it into place.
  19. Google Pixel 9 Pro Battery Replacement, Disconnect the 5G mmWave antenna: passo 19, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Disconnect the 5G mmWave antenna: passo 19, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the mmWave antenna press connector from the top right corner of the logic board.
  20. Google Pixel 9 Pro Battery Replacement, Disconnect the front facing camera: passo 20, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Disconnect the front facing camera: passo 20, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the front facing camera press connector.
  21. Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave antenna screw: passo 21, immagine 3 di 3
    • Be very careful not to touch the cameras during this step. If you accidentally do, wipe them with a clean microfiber or lint‑free cloth.
    • Carefully hold the front facing camera cable out of the way so you can access the mmWave antenna screw.
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the mmWave antenna.
  22. Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave antenna: passo 22, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the 5G mmWave antenna: passo 22, immagine 2 di 2
    • Use tweezers or your fingers to remove the mmWave antenna.
    • During reassembly, make sure the mmWave antenna goes under the front facing camera cable.
  23. Google Pixel 9 Pro Battery Replacement, Disconnect the logic board cables: passo 23, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the logic board cables: passo 23, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the logic board cables: passo 23, immagine 3 di 3
    • Use the flat end of a spudger to pry up and disconnect the press connector near the bottom left corner of the logic board.
    • Use the point of a spudger to disconnect the press connector just to the right of the previous one.
  24. Google Pixel 9 Pro Battery Replacement: passo 24, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement: passo 24, immagine 2 di 2
    • Insert the tip of an opening pick under the top edge of the press connector near the bottom right corner of the logic board.
    • Be very careful not to damage the small, surface-mounted components to the right of the connector.
    • Use the pick to pry up and disconnect the press connector.
  25. Google Pixel 9 Pro Battery Replacement, Move the charging board cover: passo 25, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Move the charging board cover: passo 25, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the charging board cover.
  26. Google Pixel 9 Pro Battery Replacement: passo 26, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement: passo 26, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement: passo 26, immagine 3 di 3
    • Use your fingers to pull the right edge of the charging board cover towards the top of your phone to unclip the left side of the cover.
    • Flip the cover away from the charging board so you can access its press connectors.
  27. Google Pixel 9 Pro Battery Replacement, Disconnect the charging board cables: passo 27, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the charging board cables: passo 27, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the charging board cables: passo 27, immagine 3 di 3
    • Be very careful not to damage any of the small, surface‑mounted components on the charging board.
    • Use the point of a spudger to pry up and disconnect the three press connectors on the top edge of the charging board.
  28. Google Pixel 9 Pro Battery Replacement, Remove the left interconnect cable: passo 28, immagine 1 di 1
    • Use your fingers to remove the left interconnect cable.
  29. Google Pixel 9 Pro Battery Replacement, Remove the right interconnect cable: passo 29, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the right interconnect cable: passo 29, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.5 mm‑long screws securing the bottom of the right interconnect cable.
  30. Google Pixel 9 Pro Battery Replacement: passo 30, immagine 1 di 1
    • Use your fingers to remove the right interconnect cable.
  31. Google Pixel 9 Pro Battery Replacement, Remove the antenna board cover: passo 31, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the antenna board cover: passo 31, immagine 2 di 2
    • Use a Torx Plus 3IP screwdriver to remove the 5.4 mm‑long screw securing the antenna cover in the top left corner.
  32. Google Pixel 9 Pro Battery Replacement: passo 32, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement: passo 32, immagine 2 di 2
    • Use tweezers or your fingers to remove the cover.
  33. Google Pixel 9 Pro Battery Replacement, Disconnect the antenna board: passo 33, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the antenna board: passo 33, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Disconnect the antenna board: passo 33, immagine 3 di 3
    • Use the point of a spudger to pry up and disconnect the autofocus sensor press connector from the top left corner.
    • Carefully move the cable out of the way so you can access the metal antenna connector underneath.
  34. Google Pixel 9 Pro Battery Replacement: passo 34, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement: passo 34, immagine 2 di 2
    • Slide one arm of your angled tweezers under the metal neck of the antenna connector and lift straight up to disconnect it.
    • To reconnect, hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  35. Google Pixel 9 Pro Battery Replacement, Remove the logic board: passo 35, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Remove the logic board: passo 35, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Remove the logic board: passo 35, immagine 3 di 3
    • Use a spudger to pry up the top edge of the logic board until you can grip it with your fingers.
    • Grip the right side of the logic board and remove it, being careful not to snag the front facing camera and battery cables.
    • During reassembly, hold the front facing camera cable out of the way and lower the logic board into place.
  36. Google Pixel 9 Pro Battery Replacement, Reassembly information: passo 36, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Reassembly information: passo 36, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Reassembly information: passo 36, immagine 3 di 3
    • During reassembly:
    • Check the condition of the logic board thermal pad—it will either be on the bottom of the logic board or on the frame.
    • If the pad is undamaged, skip the rest of this step.
    • If the pad is damaged, use the flat end of a spudger to scrape it up and remove it.
    • Use isopropyl alcohol (greater than 90%) and a microfiber cloth to remove all thermal pad residue from the frame and bottom of the logic board.
    • Apply a new thermal pad to its spot on the frame.
  37. Google Pixel 9 Pro Battery Replacement, Detach the battery pull tabs: passo 37, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Detach the battery pull tabs: passo 37, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Detach the battery pull tabs: passo 37, immagine 3 di 3
    Finger Stalls
    $8.99
    • Use your fingers to peel up the plastic tabs near the bottom edge of the battery.
    • Fold the tabs under the phone or tape them out of the way so they don't warp when heating the battery in the next step.
    • Wear finger stalls to help get a solid grip on the battery pull tabs in the next few steps.
    • If you don't have finger stalls, you can use rubber gloves instead.
  38. Google Pixel 9 Pro Battery Replacement, Heat the battery: passo 38, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Heat the battery: passo 38, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Heat the battery: passo 38, immagine 3 di 3
    • Before starting the battery removal process, carefully read the next three steps. The pull tabs are most effective immediately after heating the battery, so you'll want to know exactly what to do before starting the process.
    • Strong strips of adhesive secure the battery to the frame. Heating the battery will soften the adhesive, making it easier to separate.
    • Use a hair dryer on High heat and Low speed settings to heat the battery for three minutes, while holding the hair dryer about three inches from the battery. Try to evenly spread the heat over the entire surface of the battery.
    • Alternatively, you can use a heat mat at 70 °C (158 °F) with your phone placed screen side down for 10 minutes.
  39. Google Pixel 9 Pro Battery Replacement, Secure the phone to your work surface: passo 39, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Secure the phone to your work surface: passo 39, immagine 2 di 2
    Heavy-Duty F-Clamp
    $13.99
    • Since the battery pull tabs require two hands, you'll need to firmly secure the phone to your work surface.
    • Before securing your phone, make sure nothing is under it. Only secure the phone by the raised lip of the frame, and be very careful not to press down on any internal components.
    • Move the pull tabs out from under your phone so they're accessible.
    • Use F‑Clamps or C‑Clamps to secure the phone to your work surface. At minimum, you'll need two clamps—one for the top edge and one for the bottom edge.
    • Use clamps with plastic or rubber pads, or be extra careful not to scuff your device.
    • If you don't have any clamps, have a friend hold the phone firmly in place.
    • Make sure to follow ESD precautions when securing the phone.
  40. Google Pixel 9 Pro Battery Replacement, Separate the battery adhesive: passo 40, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Separate the battery adhesive: passo 40, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Separate the battery adhesive: passo 40, immagine 3 di 3
    • Pull straight up on both of the battery pull tabs and apply constant, steady pressure until the battery separates from the frame.
    • If the battery doesn't separate after one minute of steady pressure, apply more heat and try again.
    • Remove the battery.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    • If you successfully removed the battery, congratulations! Skip down seven steps for reassembly information.
    • If the pull tab broke or accidentally slipped out from under the battery, don't worry! Go to the next step for an alternate battery removal method.
  41. Google Pixel 9 Pro Battery Replacement, Apply isopropyl alcohol: passo 41, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Apply isopropyl alcohol: passo 41, immagine 2 di 2
    • During the next two steps, don't apply more isopropyl alcohol than instructed, or you may damage your screen.
    • Apply two or three drops of isopropyl alcohol (greater than 90%) to the top corners of the battery.
  42. Google Pixel 9 Pro Battery Replacement: passo 42, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement: passo 42, immagine 2 di 2
    • Apply two or three drops of isopropyl alcohol (greater than 90%) to the bottom corners of the battery.
    • Wait one minute to allow the alcohol to soften the battery adhesive.
  43. Google Pixel 9 Pro Battery Replacement, Apply a large suction cup: passo 43, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Apply a large suction cup: passo 43, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Apply a large suction cup: passo 43, immagine 3 di 3
    Heavy-Duty Suction Cups (Pair)
    $14.95
    • A heavy‑duty suction cup works very well for battery removal, but you can also use a smaller suction handle. If you're using the smaller suction handle, apply it to the bottom edge of the battery and skip down two steps.
    • Pull the handle on the large suction cup down to open it.
    • Use your fingers to fold the plastic battery tabs fully out of the way of the battery.
    • Place the suction cup in the center of the battery.
  44. Google Pixel 9 Pro Battery Replacement: passo 44, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement: passo 44, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement: passo 44, immagine 3 di 3
    • While gently pressing down on the suction cup, pull the handle up to lock it.
    • Flip the plastic clip on top of the suction cup over the handle and clip it to latch the handles together.
  45. Google Pixel 9 Pro Battery Replacement, Pry up the battery: passo 45, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Pry up the battery: passo 45, immagine 2 di 2
    • With one hand, firmly secure the phone to your work surface.
    • With your free hand, pull the suction cup towards the bottom of your phone with strong, steady force to lift the top edge of the battery. Apply constant pressure with the suction cup to allow time for the adhesive to separate.
    • If the battery doesn't budge after one minute, apply two to three drops of alcohol to the corners of the battery and try again. It may take multiple cycles of alcohol and steady pressure to detach the battery.
  46. Google Pixel 9 Pro Battery Replacement, Remove the battery: passo 46, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Remove the battery: passo 46, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Remove the battery: passo 46, immagine 3 di 3
    • Remove the battery from its recess.
    • Take the suction cup off the battery.
    • If the battery pull tab stayed in the recess, remove it.
  47. Google Pixel 9 Pro Battery Replacement, Remove the old battery adhesive: passo 47, immagine 1 di 2 Google Pixel 9 Pro Battery Replacement, Remove the old battery adhesive: passo 47, immagine 2 di 2
    • Use a spudger to scrape up and remove all the old battery adhesive from the frame.
    • Once all the old adhesive has been removed, use isopropyl alcohol (greater than 90%) and a microfiber cloth to clean up any adhesive residue.
    • Allow the frame to completely dry before installing a replacement battery.
  48. Google Pixel 9 Pro Battery Replacement, Adhere the battery: passo 48, immagine 1 di 3 Google Pixel 9 Pro Battery Replacement, Adhere the battery: passo 48, immagine 2 di 3 Google Pixel 9 Pro Battery Replacement, Adhere the battery: passo 48, immagine 3 di 3
    Tesa 61395 Tape
    $2.99
    • Remove any tape or liners from the battery cable.
    • Remove the larger plastic liner from the bottom of the battery to expose the adhesive.
    • If your battery doesn't have adhesive pre‑installed, apply strips of thin, double‑sided tape to the frame where the old adhesive was.
    • Firmly press the battery into its recess to secure it with the adhesive.
Conclusione
To reassemble your device, follow these instructions in reverse order starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
For optimal performance, calibrate your newly installed battery after completing this guide.
Altre 3 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
148.862 Reputazione
995 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.589 Guide realizzate
2Commenti sulla guida
Hello team, does this genuinely not need any heat for softening the adhesive in the first steps?
matteventu - Replica
Looks like nope, but it won't hurt to heat it to not damage anything, it is always easier to heat and loose adhesive!
XdekHckr -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 135
Ultimi 30 Giorni: 654
Tutti i Tempi: 10,414
