Introduzione
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the screen on your Google Pixel 4 XL.
Note: Follow this guide to replace a screen that's pre-installed in a new frame (a.k.a. chassis). You'll need to transplant all of your phone's internals to the new screen. If you're replacing the display panel by itself, follow this guide instead.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
This guide requires a replacement battery. Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
Cosa ti serve
Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
Press firmly to eject the tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick across the bottom towards the left corner to slice the adhesive.
With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it on the left edge of the phone for one minute.
Prepare an iOpener and apply it on the right edge of the phone for one minute.
Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
Do not try to pull the panel all the way off yet, as it is still connected to the phone.
Remove the four T3 Torx screws securing the battery connector shield:
One 1.8 mm screw
One 4.1 mm screw
One 4.4 mm shouldered screw
One 4.0 mm shouldered screw
Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
Use blunt tweezers to lift up the battery adhesive pull tabs so you can more easily grip them with your fingers.
Pull on the black pull tab at a shallow angle with steady force. When the adhesive grows long, roll it around a spudger and continue pulling.
Continue firmly pulling up on the adhesive strip with constant force, spinning the spudger every so often to keep the exposed section of the pull tab as short as possible.
Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
Lift the battery up, away from the phone to remove it.
Remove any remaining adhesive from the battery well.
If you're using stretch release adhesive, apply them onto the battery. Otherwise, apply some double-sided tape, or pre-cut adhesive strips in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
Lay the battery in place and press firmly.
Disconnect the battery connector from its motherboard socket and resume re-assembly.
Use your T3 Torx screwdriver to remove the following screws securing the rear-facing camera connector cover:
One 2.7 mm screw
One 4.1 mm screw
One 4.2 mm screw
Use the pointed end of your spudger to pry the camera and sensor connectors straight up from the motherboard to disconnect them.
Use your T3 Torx screwdriver to remove the following screws from the front camera and sensor assembly:
Two 2.7 mm screws
One 3.1 mm screw
Use your T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
Use a pair of tweezers to remove the display connector cover.
Use the flat end of a spudger to disconnect the display connector from the motherboard.
Use your T3 Torx driver to remove the 2.7 mm screw securing the motherboard to the frame.
Use the pointed end of your spudger to disconnect the three side button and rear-facing camera connectors from the motherboard.
Use a pair of tweezers to disconnect the two coaxial antenna connectors from the motherboard.
Use your spudger to pry up and loosen the top edge of the motherboard.
Use a pair of tweezers to remove the rear-facing camera module.
Use a T3 Torx driver to remove the 2 mm screw securing the antenna connector board board to the phone.
Use your T3 Torx screwdriver to remove the three screws securing the loudspeaker:
One 4.1 mm screw
One 2.7 mm screw
Use the pointed end of your spudger to disconnect the two antenna press connectors from the charging assembly.
Peel back the ribbon cable until it is fully separated from the frame.
Remove the charging assembly.
Use a T3 Torx driver to remove the 3 mm screw securing the bottom microphone assembly to the bottom right corner of the frame.
Insert the pointed end of a spudger underneath the antenna's ribbon cable and gently pry up to peel the cable from the frame.
Remove the antenna.
Use a pair of pliers to firmly grip the vibration motor near the bottom right of the device.
Pull straight up with steady force until the motor separates from the frame.
Altre 4 persone hanno completato questa guida.
