Salta al contenuto principale
Garmin inReach Explorer Plus LCD Screen Replacement
Sean Kelley
Sean Kelley e 2 altri collaboratori
Ultimo aggiornamento il 28 dic 2021
20 - 35 minuti
Moderato
Necessarie Immagini Migliori
Necessarie Più Immagini
Introduzione
Vai al passo 1
This guide will be used if your Garmin inReach Explorer+ has screen issues. The guide will go over the process to replace the LCD screen. The LCD screen is a key component of the GPS, showing the visuals of the GPS and any selections that are made with the buttons.
As mentioned in our troubleshooting guide, the screen issues could be a frozen or damaged screen. The troubleshooting guide has several solutions that should be attempted prior to replacing the screen such as performing updating the device and resetting the device.
Before you begin replacing the screen, make sure it is powered off and it is not connected to any other form of power.
Cosa ti serve
Strumenti
Mostra di più…
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the back cover.
  3. Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, immagine 2 di 2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, immagine 2 di 2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, immagine 2 di 2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 1 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 2 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 3 di 3
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 1 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 2 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 3 di 3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Sean Kelley
Membro da: 09/28/21
387 Reputazione
4 Guide realizzate
Clemson, Team 5-4, Hunter Fall 2021 Membro di Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Membri
5 Guide realizzate
3Commenti sulla guida
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Replica
Ditto - where can we get a screen??
Ben Wallbank - Replica
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,259
