Salta al contenuto principale
DualSense Controller v2 Joystick Cover Replacement
Sam Omiotek
Sam Omiotek e 2 altri collaboratori
Ultimo aggiornamento il 8 mar 2025
30 minuti - 1 ora
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
Follow this guide to replace the joystick covers on your Sony DualSense controller.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: passo 1, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: passo 1, immagine 2 di 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: passo 2, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: passo 2, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: passo 2, immagine 3 di 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: passo 3, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: passo 3, immagine 2 di 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: passo 4, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: passo 4, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: passo 4, immagine 3 di 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: passo 5, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: passo 5, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: passo 5, immagine 3 di 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: passo 6, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: passo 6, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: passo 6, immagine 3 di 3
    • Insert the flat end of your spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: passo 7, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: passo 7, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: passo 7, immagine 3 di 3
    • Insert the flat end of your spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Joystick Cover Replacement, Remove the case screws: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Joystick Cover Replacement: passo 9, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: passo 10, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: passo 10, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: passo 10, immagine 3 di 3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: passo 11, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: passo 11, immagine 2 di 2
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
    You can´t just grab both ends and expect it to open flawlessly, first you gotta travel the spudger around the seam at the outer edges of the controller, there are multiples clips in that area, there a couple really hard to get out at the outer edges of the R1 and L1 buttons, for those you need to insert the spudger bending outwards the bottom piece of the controller (a fairly amount, like 1.5mm) and while bending outwards use the same inserted spudger to lever them apart carefully, the plastic will bend quite a bit so be very careful with the motion of the spudger.
    Yet again, that was my personal experience opening it up, try first as the guide says, if you feel the upper and bottom pieces glued around the R1 and L1, then try this.
    Carlos Santana - Replica
    I had the same experience, the best way to reach these for me was to place the spunger from L1 R1 side whilst using a spunger to press outwards from the side like in Carlos's comment. Thank you Carlos I was struggling with this!
    Remco geuze -
    This did not work for me. Finally I just pulled the two parts apart at the bottom side, carefully twisting and manipulating until the parts clicked loose at the top side
    Gilian Mischker -
    This is the biggest hassle in the whole process. It seems that all controllers now come with those extra clips that other people mentioned here. I, however, didn't have the same success with their steps of running a spudger on the sides to undo the clip. Looking around, I found this Youtube video showing that you can undo the clips simply by twisting up from the bottom. Do it carefully because it pops off easily using this method - when I did, I used some force and the back just flew from my table.
    I found it easier like that and was able to continue the process.
    Rodrigo Castro - Replica
    +1 to this. None of the suggestions worked well enough for me, but this video clip got this step done for me nearly instantly. note the position of the tech's fingers and thumbs - I copied that exactly and had no issue.
    Nathan K -
  12. DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: passo 12, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: passo 12, immagine 2 di 2
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: passo 13, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: passo 13, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Joystick Cover Replacement, Remove the battery: passo 14, immagine 1 di 1
    • Remove the battery.
  15. DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: passo 15, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: passo 15, immagine 2 di 2
    • Use the pointed end of your spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Joystick Cover Replacement: passo 16, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement: passo 16, immagine 2 di 2
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Joystick Cover Replacement, Remove the battery bracket: passo 17, immagine 1 di 1
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Joystick Cover Replacement: passo 18, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement: passo 18, immagine 2 di 2
    • Lift the battery bracket off of the motherboard.
    The bottom left and right tabs of the battery bracket are meant to protect and retain the motor wires. In this guide step, you can see the wires are wound around the bracket. Move the wires behind this bracket and you won't have to worry about pinching the wires while reassembling the rear case.
    Lone - Replica
  19. DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: passo 19, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: passo 19, immagine 2 di 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
    I think the cable you see here is put in backwards. The "Double Line" pull tab should connect to the motherboard.
    Lone - Replica
    TRADUCCION:
    Creo que el cable que se ve aquí está puesto al revés. La lengüeta de tiro "Doble línea" debe conectarse a la placa base.
    Carlos López (España - Spain) - Replica
  20. DualSense Controller v2 Joystick Cover Replacement: passo 20, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement: passo 20, immagine 2 di 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on your model controller, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: passo 21, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: passo 21, immagine 2 di 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Joystick Cover Replacement: passo 22, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement: passo 22, immagine 2 di 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: passo 23, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: passo 23, immagine 2 di 2
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
    per sbaglio ho tirato forte la linguetta arancione in basso a destra e non so più dove inserirla
    xXGabriele Massaro7Xx - Replica
  24. DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: passo 24, immagine 1 di 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: passo 24, immagine 2 di 2
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: passo 25, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: passo 25, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: passo 25, immagine 3 di 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
    There's small tabs holding the board in place along the side.
    Roger Perez - Replica
  26. DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: passo 26, immagine 1 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: passo 26, immagine 2 di 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: passo 26, immagine 3 di 3
    • Use your fingers to pull the joystick covers straight up and off of their modules.
    What thought was controller wear and tear/drift was actually hair/debris on potentiometers. Ifixit does it again thank you saved me 70 for brand new controller.
    Benjamin Roman - Replica
    Adding replaced everything, still had problems so I had to open dualsense again and go deeper and clean out the potentiometer and contact points with alcohol. Seems to be fixed now, be careful, small intricate parts and there’s a pronounced stickiness feel to my thumb stick like something is off. But the drift is gone so hopefully it will even itself out.
    Benjamin Roman -
Conclusione
Altre 9 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Sam Omiotek
Membro da: 02/25/19
87.790 Reputazione
290 Guide realizzate
2Commenti sulla guida
cant you just glue it.
Joseph Galante - Replica
Will it help with stick drifts?
גיא מוסרי - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 20
Ultimi 7 Giorni: 195
Ultimi 30 Giorni: 819
Tutti i Tempi: 16,789
