Salta al contenuto principale
Dirt Devil Gator Charger Replacement
Ryan Marando
Ryan Marando e 3 altri collaboratori
Ultimo aggiornamento il April 29, 2020
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
If your Dirt Devil Gator (Model Number: BD10100) isn’t powering on or remaining charged, you may need to replace the charger port. Follow this guide to replace the charger port on your device.
However before using this guide, you may not need to fully replace the charger port! A dead battery is a simple problem with a quick fix to get you started vacuuming again quickly!
The charger port on the Dirt Devil Gator allows the device to have power and maintain charge. But a destroyed/malfunctioning charger port will not charge the device, resulting in a possible replacement needing to occur.
Step 5 requires you to remove the charger port from the motor. From there you must desolder and cut wires to replace the old charger port with the new one. Follow this guide to solder and desolder connections properly!
Before beginning, make sure to power off your device completely and disconnect from any external power source.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Dirt Devil Gator Charger Replacement, Charger: passo 1, immagine 1 di 1
    • Press the button on the middle of the vacuum by pushing down on it and pulling the device apart.
  2. Dirt Devil Gator Charger Replacement: passo 2, immagine 1 di 3 Dirt Devil Gator Charger Replacement: passo 2, immagine 2 di 3 Dirt Devil Gator Charger Replacement: passo 2, immagine 3 di 3
    • Separate the front and back half of the vacuum.
    • Pull on the back of the vacuum, there should not be too much resistance when pulling it out.
  3. Dirt Devil Gator Charger Replacement: passo 3, immagine 1 di 3 Dirt Devil Gator Charger Replacement: passo 3, immagine 2 di 3 Dirt Devil Gator Charger Replacement: passo 3, immagine 3 di 3
    • Unscrew each individual 13 mm screws with a micro screwdriver from the vacuum.
    • After unscrewing all of the screws, firmly pull on the side of the vacuum to separate the exterior.
  4. Dirt Devil Gator Charger Replacement: passo 4, immagine 1 di 3 Dirt Devil Gator Charger Replacement: passo 4, immagine 2 di 3 Dirt Devil Gator Charger Replacement: passo 4, immagine 3 di 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Charger Replacement: passo 5, immagine 1 di 1
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 13
Tutti i Tempi: 957
