Salta al contenuto principale
Dell XPS 13 9305 SSD Replacement
Clay Eickemeyer
Clay Eickemeyer e 2 altri collaboratori
Ultimo aggiornamento il April 1, 2023
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will demonstrate how to remove and replace the Solid State Drive (SSD) in your Dell XPS 13 9305. Use this guide if you're upgrading your SSD, replacing an existing SSD, or transferring an SSD from another computer.
Note that the SSD shield is only required for 30 mm-long (M.2 2230) SSDs. If you install an 80 mm-long full size (M.2 2280) SSD, do not install the shield. This will be described again in the relevant step below.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Dell XPS 13 9305 SSD Replacement, Remove the back screws: passo 1, immagine 1 di 2 Dell XPS 13 9305 SSD Replacement, Remove the back screws: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 SSD Replacement, Release the clips: passo 2, immagine 1 di 2 Dell XPS 13 9305 SSD Replacement, Release the clips: passo 2, immagine 2 di 2
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 SSD Replacement, Remove the back cover: passo 3, immagine 1 di 3 Dell XPS 13 9305 SSD Replacement, Remove the back cover: passo 3, immagine 2 di 3 Dell XPS 13 9305 SSD Replacement, Remove the back cover: passo 3, immagine 3 di 3
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: passo 4, immagine 1 di 3 Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: passo 4, immagine 2 di 3 Dell XPS 13 9305 SSD Replacement, Disconnect the battery cable: passo 4, immagine 3 di 3
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 SSD Replacement, Remove the screw from the SSD cover: passo 5, immagine 1 di 2 Dell XPS 13 9305 SSD Replacement, Remove the screw from the SSD cover: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the 3.7 mm-long screw from the SSD cover.
    • This cover won't be used if an 80 mm-long full-size SSD is installed.
  6. Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: passo 6, immagine 1 di 3 Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: passo 6, immagine 2 di 3 Dell XPS 13 9305 SSD Replacement, Pull the SSD cover off: passo 6, immagine 3 di 3
    • Pull the cover off and away from the silver retaining peg.
    • During reassembly, don't install this cover if you're upgrading to a full-size SSD. The cover is needed only for 30 mm-long (M.2 2230) SSDs.
  7. Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: passo 7, immagine 1 di 3 Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: passo 7, immagine 2 di 3 Dell XPS 13 9305 SSD Replacement, Remove the SSD by hand: passo 7, immagine 3 di 3
    • Grab the SSD by the corners. Be gentle to not pull up on the SSD.
    • Pull it straight out from the socket. If it feels stuck, wiggle it side to side.
  8. Dell XPS 13 9305 SSD Replacement, Reassembly notes: passo 8, immagine 1 di 1
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Altre 2 persone hanno completato questa guida.
Clay Eickemeyer
Membro da: 09/19/22
82.630 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.513 Guide realizzate
2Commenti sulla guida
I don't know whether anyone had the same experience, but the SSD keeps disconnecting sometimes. Does anyone have any idea whether it is possible to put something inside so that it keeps the SSD seated properly in the slot?
Aleš Sršeň - Replica
If it's a long SSD, did you remove the shield?
Franck Quintana -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 73
Tutti i Tempi: 3,005
