Salta al contenuto principale
DJI Mini 2 Main Board  Replacement
Parker Sowersby
Parker Sowersby e 5 altri collaboratori
Ultimo aggiornamento il July 7, 2024
30 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
This guide will show you how to successfully replace the main board inside the DJI Mini 2 drone.
The main board in the DJI Mini 2 helps the drone tell the other parts of the drone what to do and connects the controller and phone connected to the drone. If the main board is damaged the drone will not function or connect to the controller and phone the user wants to connect to. For more information on what may be causing your issue, check out the Troubleshooting page for this device.
This guide requires the use of ESD-safe tools to avoid damaging the motherboard or other sensitive components.
After replacing the motherboard, you will need to calibrate your DJI Mini 2 drone. Some calibration processes can be done with the DJI Fly mobile app, but for some processes, like gimbal calibration, you will need to use additional software. How to calibrate the gimbal watch this video tutorial https://youtu.be/mu03HWXplM4
Cosa ti serve
Strumenti
Mostra di più…
Panoramica Video
  1. DJI Mini 2 Main Board  Replacement, Battery: passo 1, immagine 1 di 2 DJI Mini 2 Main Board  Replacement, Battery: passo 1, immagine 2 di 2
    • Face the DJI Mini 2 away from you so that you are looking at the charging ports.
    • Use your finger to open up the back panel.
  2. DJI Mini 2 Main Board  Replacement: passo 2, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 2, immagine 2 di 2
    • Pinch the locking mechanism on the battery to release the lock.
    • Pull the battery straight out of the compartment.
    Honestly, did we need an ifixit tutorial on THIS?!
    Next up, how to insert the battery.
    Big Ed - Replica
    @big_ed Perhaps author wanted to make sure no electric issues to occur @people who are not aware of possible damages whilst having battery still inside.. Next up, a smart remark?
    Ruud - Replica
    Merci 🔥 pour le tuto j'avais oublié comment on fait
    Layoness Record - Replica
    Merci à vous pour ce bref mais incontournable tutoriel permettant l'accès à la batterie !
    Albert Brian Frank - Replica
    Dieses Tutorial kann nicht ernst gemeint sein - oder doch?!
    thomas01 - Replica
  3. DJI Mini 2 Main Board  Replacement, Drone Body: passo 3, immagine 1 di 2 DJI Mini 2 Main Board  Replacement, Drone Body: passo 3, immagine 2 di 2
    • Unfold the wings of the drone.
    • Place the drone upside down on a flat surface.
    • There should be stickers on the device telling you how to unfold the propeller arms.
  4. DJI Mini 2 Main Board  Replacement: passo 4, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 4, immagine 2 di 2
    • Remove the four 5 mm J000 screws near each propeller arm.
  5. DJI Mini 2 Main Board  Replacement: passo 5, immagine 1 di 3 DJI Mini 2 Main Board  Replacement: passo 5, immagine 2 di 3 DJI Mini 2 Main Board  Replacement: passo 5, immagine 3 di 3
    • Flip the drone back over.
    • Use a combination of the opening tool and your fingers to pry open the top panel of the drone along the seams.
  6. DJI Mini 2 Main Board  Replacement: passo 6, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 6, immagine 2 di 2
    • Remove the two 5 mm J000 screws located in the battery hatch and near the ports on the back of the drone.
  7. DJI Mini 2 Main Board  Replacement: passo 7, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 7, immagine 2 di 2
    • Flip the drone over again.
    • Pry off the bottom panel of the drone using the opening tools and your fingers.
  8. DJI Mini 2 Main Board  Replacement, Main Board: passo 8, immagine 1 di 3 DJI Mini 2 Main Board  Replacement, Main Board: passo 8, immagine 2 di 3 DJI Mini 2 Main Board  Replacement, Main Board: passo 8, immagine 3 di 3
    • Remove the three 3mm J000 screws on the black plate.
  9. DJI Mini 2 Main Board  Replacement: passo 9, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 9, immagine 2 di 2
    • Use your fingers to pull the black plate off to reveal main board.
  10. DJI Mini 2 Main Board  Replacement: passo 10, immagine 1 di 3 DJI Mini 2 Main Board  Replacement: passo 10, immagine 2 di 3 DJI Mini 2 Main Board  Replacement: passo 10, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Try to avoid disturbing the blue thermal paste covering two of the large board components. If the paste is disturbed or splotchy in places it may need to be removed and reapplied. For more information refer to the How to Apply Thermal Paste guide.
    • Using ESD Safe Tweezers Blunt Nose, remove the 5 cables attached to the main board.
  11. DJI Mini 2 Main Board  Replacement: passo 11, immagine 1 di 2 DJI Mini 2 Main Board  Replacement: passo 11, immagine 2 di 2
    • Use the ESD Safe Tweezers Blunt Nose and your fingers to pull off the main board from the drone carriage.
    note: the connectors are stuck with a hotglue sometimes, so be careful. i suggest heating gently before attempting to break the glue.
    jcollins1905 - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
2Commenti sulla guida
I found this mini 2 post interesting, even if i want to do somthing
different.
my goal is to install the old motherboard in newer hardware...
gimbal. IMU board barometer/compass busted after the super
90 deg DJI off function, because of a gust... crash,'i really
LOVE DJI.....NOT!"
then I ask to buy parts from them, then they babble
about warranty.... nope bro we are not selling parts
forget it we want to repair it.... forget it, it's my drone
i rather sledge hammer it on YouTube.
so this is last resort transplanting a board with old
firmware, I don't want to use a new bird with more stupid
chiness software, that has no real bearing of local aeronautical
laws.
not using them otherwise. goodbye DJI
Do never buy a Chinese drone! From crappy company
might look here again
albi - Replica
Great advice, thank you.
mauricio vilchez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 146
Tutti i Tempi: 6,866
