Salta al contenuto principale
Anker 2.4G Wireless Mouse Left and Right Button Replacement
Vincent Lee
Vincent Lee e 10 altri collaboratori
Ultimo aggiornamento il November 27, 2022
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the left and right mouse buttons on your Anker 2.4G Wireless Mouse.
A mouse button is an electrical switch on the mouse which allows a user to interact with a graphical user interface. They will eventually wear out through continuous use. If you notice the left or right mouse button not working properly all of the time, you may need to replace the left or right mouse button.
Please be sure to check out the troubleshooting page before using this guide. Often times, malfunctioning mouse buttons are a software issue and can be fixed without replacing the left and right mouse buttons.
Step 7 in this guide requires you to desolder the mouse buttons and solder new ones in place.
Make sure that the mouse is turned off before starting.
Cosa ti serve
Strumenti
Mostra di più…
  1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: passo 1, immagine 1 di 1
    • Peel off the stickers. This will reveal the location of four screws.
  2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 2, immagine 1 di 1
    • Remove the four screws using a Phillips #0 screwdriver.
  3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, immagine 1 di 2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 3, immagine 2 di 2
    • Use a spudger to pry apart the upper and lower housing of the mouse.
  4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 4, immagine 1 di 1
    • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
    • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
  5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 5, immagine 1 di 1
    • Remove the scroll wheel from the mother board by pulling it to the left.
    • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
  6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 6, immagine 1 di 1
    • Pull the mother board gently away from the plastic housing.
  7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, immagine 1 di 2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: passo 7, immagine 2 di 2
    • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
Conclusione
Altre 2 persone hanno completato questa guida.
Vincent Lee
Membro da: 01/23/14
361 Reputazione
3 Guide realizzate
Cal Poly, Team 1-39, Maness Winter 2014 Membro di Cal Poly, Team 1-39, Maness Winter 2014
CPSU-MANESS-W14S1G39
4 Membri
16 Guide realizzate
2Commenti sulla guida
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - Replica
where can these replacement button switches be purchased….thanks ric
Ric Scambler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,702
