Batteria
9 Risposte Punteggio 4 |
It has died and won’t turn back on. |
1 Risposta Punteggio 0 |
FitBit Ionic, can you replace the charging port? |
1 Risposta Punteggio 2 |
Replace screen Ionic - Ionic |
It does not charges |
Ricambi
Strumenti
Questi sono alcuni strumenti di uso comune usati per lavorare su questo dispositivo. Potrebbe non essere necessario ogni strumento per ogni procedura.
Background and Identification
The Fitbit Ionic is a smartwatch made by Fitbit and released in 2017. It uses GLONASS, a global satellite navigation system for built-in GPS as well as SmartTrack to record user activity on the Fitbit app. It’s predecessors were the Fitbit Blaze and Surge and in 2018, Fitbit released the Fitbit Versa along with an update to the Ionic with the Fitbit OS 2.0.
The Fitbit Ionic has a steel case and rubberized band. It has a rectangular full-color screen and though it’s similar to the Blaze’s screen, it’s bigger because the bezels are thinner. The Fitbit logo is placed just below the screen. It comes in Charcoal, Blue Gray and Slate Blue. The bands can be changed out, there are leather and plastic strap options.
Some of the features of the watch include battery life that lasts up to four or five days. It is also water resistant up to 50m. It has 2.5GB of space to upload music. There is also a heart rate monitor which is easy to access and gives instant readings on the main display.
The Fitbit Ionic was voluntarily recalled in the United States in March of 2022. "The battery in the Ionic smartwatch can overheat, posing a burn hazard," according to Fitbit.
Specifications
Release date: August 2017
Dimensions and Weight: 35.99 × 21 × 29.23 mm (1.42 × 0.83 × 1.15 in), 49.89 g (1.76 oz)
Display :
- Corning Gorilla Glass 3
- 348 × 250 Pixels, 1.4 Inch, 306 ppi
Body Material: Aluminum
Max Depth of Water Resistance: 164 ft
Protection: 5ATM waterproof
Operating System: Fitbit OS
Processor:
- Toshiba ARM Cortex M4F 120 MHz, 32 Bit
- Chipset: TZ1201XBG
RAM and Storage: 2,5 GB internal storage
Battery:
- Lithium-polymer
- Magnetic charging
Sensors: 3-axis accelerometer, altimeter, optical heart rate monitor, ambient light sensor
Wireless Interface:
- Bluetooth, IEEE 802.11b/g/n, NFC
- GPS and GLONASS
Tracking data: Active time, activity, calories burned, distance, floors climbed, heart rate, pace, sleep activity, sleep stages, steps taken, swim laps
Supported Host Device Platform: Android, Windows Phone, iOS
