Salta al contenuto principale
Smart Watch with GPS tracker and music player on bluetooth
22 Domande Visualizza tutte
Replace screen Ionic - Ionic
I have an Ionic with a damaged screen and the replacement worked until last week firmware update… it is dead since then…
How could I replace the screen from the dead one to the broken screen but working ?
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 1
Commenti:
I found this tutorial on youtube: https://www.youtube.com/watch?v=vZdALycI.... Would be great to see it on IFixit along with parts....
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Remove the strap from the wrist
heat the watch slowly to approx. 80 degrees Celsius
gently(!) place a opening tool between the glass and the frame of the watch and lift the glass carefully and slowly
disconnect the connectors
replace the glass
put everything together
WARNING: Be very carefull, since the rubber seal between the glass and frame is easily damaged and you need it to seal the watch. I haven't found any spare part for this yet and I did not managed to preserve it.
Punteggio 1
Commenti:
Hi! I also have a broken glass on the Ionic. Where can i find the repair guide and parts?
da
Aggiungi la tua risposta
Jesus Fernandez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 82
Tutti i Tempi: 961
