Salta al contenuto principale
Indice dei contenuti
2003-2007 Honda Accord EX Troubleshooting
Basic Honda Accord Maintenance
Your Accord has problems that need fixing, but you don't know what to do.
Vehicle vibrates when braking
The vehicle vibrates unnaturally when the brake pedal is pushed.
Brake Pads are worn out and need replacement
The brake pads need to be replaced. Learn how to replace the brake pads by clicking HERE.
Rotors are warped due to intense braking
The rotors need to be replaced. Reference this website for help.
Screeching sound is heard when brake pedal is pushed
A loud screeching noise is heard when brakes are applied. This is due to the wear indicator on your brake pads contacting the brake rotor.
Brake pads are worn out and need replacement
Brake warning light turns on
The brake warning light will light up on the dashboard.
Brake pads may be worn out and need replacement
Low Oil Pressure Light turns on
The oil lamp-shaped light will light up on the dashboard. This light may indicate that engine oil levels are low.
Engine oil and oil filter need to be replaced
The engine oil and oil filter need to be changed. Learn how to check and/or change your oil by clicking HERE.
Mildew smell inside the cabin
The cabin will smell musty, damp and mildewy. Turning on the AC worsens the smell.
Cabin air filter is dirty and need to be replaced
The cabin air filter needs to be replaced. Learn how to replace the cabin air filter by clicking HERE.
Decrease in gas mileage
The vehicle's gas mileage decreases considerably after 15,000 miles, or the vehicle has been driven 15,000 miles or more without service.
Engine air filter is dirty and needs to be replaced
The engine air filter needs to be replaced. Learn how to replace the engine air filter by clicking HERE.
Vehicle makes harsh noises and vibrates excessively
The vehicle makes harsh popping and knocking sounds when starting, at idle, or accelerating. Engine vibrations are coarse and rougher than normal.
Spark plugs are worn and dirty, and need to be replaced
The spark plugs need to be replaced. Learn how to replace the spark plugs by clicking HERE.
Vehicle accelerates slowly
The vehicle displays a decrease in horsepower, and accelerates more slowly than normal.
Vehicle accelerates inconsistently and harshly
The vehicle does not accelerate as smoothly as before, and experiences unexpected spurts of acceleration or deceleration.
The spark plugs need to be replaced. Learn how to replace your spark plugs by clicking HERE.
Tires make a humming sound when driving down a smooth road
After 6000 to 8000 miles of driving, your tires may make an abnormal humming sound when driven down smooth roads.
Tires are worn unevenly, and need to be rotated
The tires need to be rotated. Learn how to rotate the tires by clicking HERE.
Vehicle drifts to one side when driven straight
When driving down a straight path, the vehicle tends to drift on its own to the right or the left. An easy way to check vehicle straightness is to hold the steering wheel completely still while driving straight. Drift will then become apparent.
Wheels are improperly aligned
The angles of the wheels are adjusted improperly. It is recommended that you take the vehicle to a service shop for alignment. If you wish to do a wheel alignment yourself, reference this website or this other website for directions.
Wheel bearing is loose
Wheel bearing is loose, causing wobble in one or more wheels. Reference this video for help. The tools required may vary from those present in the video.
Cal Poly, Team 24-27, Regan Fall 2012 Membro di Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membri
24 Guide realizzate
10 Commenti
Windows won't close just driver's side
denisenichols36 - Replica
Windows won't close
denisenichols36 -
Air conditioner won't work after replacing the battery.
Jared Ockinga - Replica
Engine stalls when you remove leg from the accelerator pedal
ogbemudiachris - Replica
Engine stalls frequently when you remove leg from accelerator pedal.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 8,378
