Introduzione
It is suggested that the cabin air filter be replaced every 15,000 miles.
Cosa ti serve
Open the passenger side door and locate the glove box. Open and empty the glove box.
Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
Push the tabs inward and gently shake the housing free while pulling straight out.
When reassembling, push the filter tray in gently until both locking tabs click into position. The filter must be inserted into the tray fully for the tray to fit back in.
Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray to prevent any particulates passing around the filter.
Altre 21 persone hanno completato questa guida.
Un commento
Good easy to understand directions and removal of cabin air filter . Thank You
