MacBook Air 13" (Late 2010-2017) Replacement Battery
  • MacBook Air 13" (Late 2010-2017) Replacement Battery / Fix Kit
  • MacBook Air 13" (Late 2010-2017) Replacement Battery / Part Only
  • 360°
360
84,99 US$
84,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
This MacBook Air 13" (Late 2010 to 2017) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 6800 mAh. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Contenuto del kit
Contenuto del kit
Nota
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Nota
A small percentage of users have experienced issues with aftermarket (non-Apple) batteries failing to be recognized properly in devices running Mac OS X El Capitan (10.11.x) or Sierra (10.12.x). If your system does not operate properly with our replacement battery, it can be returned for a full refund.
Attenzione
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibilità
MacBook Air 13" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 13" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 13" Early 2017
1.8 GHz
2.2 GHz
MacBook Air 13" Late 2010
1.86 GHz
2.13 GHz
MacBook Air 13" Mid 2011
1.7 GHz
1.8 GHz
MacBook Air 13" Mid 2012
1.8 GHz
2.0 GHz
MacBook Air 13" Mid 2013
1.3 GHz
1.7 GHz
Visualizza 4 altri dispositivi
Storie di Riparazione
Il Mio Problema
Did not want to leave it at an Apple store in Phoenix and return to pick it up. I live 2 hrs away from the nearest store
La Mia Riparazione
Very easy
Il Mio Consiglio
Lay out a container for the screws, keep track of the locations, no other possible problems
Il Mio Problema
My computer would randomly shut off when I was working off the battery, even when my meter said I had 75% battery left. I ordered a replacement battery - but I ordered the wrong size. I contacted ifixit via email - they responded very quickly - I sent back the wrong sized batter & ordered the corr . . .
Il Mio Problema
Battery was failing
La Mia Riparazione
Got it fixed in 10 minutes. Very east thanks to the included tools.
Il Mio Consiglio
Follow the instructions on the Ifixit site.
Il Mio Problema
The battery on my MacBook Air had given out. The charge would say, "Service Battery Soon" but I didn't know I could replace the battery. I checked out the guide on iFixit's site and there was one! So I bought a new battery through iFixit.
La Mia Riparazione
Once I got the battery in the mail, the replacement went flawl . . .
Il Mio Problema
Original battery would no longer last more than 60 minutes
La Mia Riparazione
Easy, my granddaughter could do it
Il Mio Consiglio
Rely on ifixit
Il Mio Problema
Battery was needing serviced. Shutting off at random. Inaccurate charge reading, only 60% of original design capacity of mAh remaining.
La Mia Riparazione
Super Easy. If you haven't done it, follow iFixit's simple walk through.
Il Mio Consiglio
It will give your machine new life, and it's worth the cost even if you plan to upgrade and s . . .
Il Mio Problema
2012 MacBook air, Service battery alert
La Mia Riparazione
Easy peasey
Il Mio Consiglio
Some things to watch out for. When removing the original battery the power cable may not flex enough to clear the connection housing on the logic board. No worries, just release it with a slight pull then remove the 5 screws holding the battery asse . . .
Il Mio Problema
Had an old MacBook Air. The battery was giving an error although it was still usable. I decided to replace the battery.
La Mia Riparazione
So easy, I watched as my 8-year-old did the work. All we needed was a couple of pentalobe-style screwdrivers.
Il Mio Consiglio
Even easier than I thought it would be.
Il Mio Problema
old battery not holding a charge anymore
La Mia Riparazione
this is for a:
Model Name: MacBook Air
Model Identifier: MacBookAir3,2
Processor Name: Intel Core 2 Duo
Processor Speed: 1.86 GHz
after first swapping the battery the rpsvchost process was jacked. tried a pram and it seemed to clear the problem but . . .
Il Mio Problema
Water was spilled on computer. Fortunately everything but the battery still worked after a couple of days of drying.
La Mia Riparazione
Super easy.
Il Mio Consiglio
I had to tighten my trackpad a little. Not sure if it's due to the battery being slightly thinner or sitting lower than original. Just something to look out for in case you . . .
Mostra di più
