Introduzione
Use this guide to replace a worn-out battery.
  • Before proceeding, power down your machine. Close the display and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm P5 Pentalobe screws
    • Eight 2.6 mm P5 Pentalobe screws
  • The special screwdriver needed to remove the ten 5-point Pentalobe screws can be found here.
These pentalobe screw sizes can't possibly be right - not even close. Should they perhaps be 0,8 mm and 1,2 mm?
Rulle Boer - Replica
The screw sizes refer to the length of the shaft, not the diameter of the head or socket. P5 is the standard pentalobe size for all these screws, regardless of length.
I agree that the notation is a little confusing. I think it's because, with standard sized hardware like for your house, you have shaft diameter (say 1/8" or 3mm) and shaft length (say 3" or 7.5cm). So we're programmed to think of small numbers like that as diameter. But in this case, they're length.
budpegasus - Replica
Pulling the fan cable out was terrifying but you actually just pull on the cable itself. No way to get any leverage at the connector to dislodge it. Did come out easily but like I said, scared me!
allison - Replica
Draai de schroefjes voorzichtig los en leg ze op een stabiele plek neer en let erop dat de schroefje een verschillende lengte hebben.
bwgvanderveer - Replica
I thought I could replace my 256 Gb SSD with 512? regards
ola m - Replica
Do you have good Test Point Voltages? It appears there are silver colored Test points on the I/O Board. I am working on a water spill and trying to troubleshoot if both the I/O board and the Logic need replaced.
andrew - Replica
It's probably not necessary but may be a little safer to completely discharge the old battery before replacing it.
Larry Smith - Replica
tell a model that was not inferior to the speed of the one in the laptop.
Thank you
ilyabuhov - Replica
Do i need to order tools separately to replace the battery i just ordered?
anne uhlir - Replica
im looking for a Logic Board for a
Apple - MacBook Air® - 13.3" Display - Intel Core i5 - 8GB Memory - 128GB Flash Storage (Latest Model) - Silver Model: MQD32LL/A
Any help is appreciated.
Jamie Comstock - Replica
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
There is a nub on the inside of the case which is attached to the battery. When you try to pull it open, it appears to be attached to the plastic casing of the battery, which sometimes splits. I gently unhooked the nub from the battery before removing the case fully. This seems to happen if the battery has suffered some drop damage (plastic parts broken around screws and parts of plastic frame split). Just an FYI in case your lower case doesn't pull away easily.
Jeannie Crowley - Replica
When closing this back up make sure that the antenna cable is tucked away neatly
Gabriel - Replica
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board. Do not lift upward on the connector as you disconnect it.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
The guide says: "Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board", but the battery model that I was replacing did not have a clear plastic pull tab at all...
The battery model shown in this guide is: A1405
I was installing battery model: A1406
A1406 has the following connector:
Top:
http://www.directupload.net/file/d/4122/...
Bottom:
By looking at the bottom of the new battery I saw how it could be removed. Simply by a gentle upward movement. I very, very carefully nudged it a bit upwards using a screwdriver on the left and right side, as shown here:
It came out fairly easy, luckily!
(And yes, I also cleaned up this MacBook before closing it again. It was a bit hairy in a literal way. Electronics and pets is not the best combination. ;-) )
This was a great guide!
wil - Replica
I think you may have been reading the wrong guide by mistake.
Looking at the various MacBook Air battery replacement guides, all of the 13" models show the connector depicted in this guide. All of the 11" models (e.g. MacBook Air 11" Mid 2012 Battery Replacement) show a connector like the one in your photos.
shamino -
The 13 inch's tab is a bit more difficult to reinstall than uninstall. Delicate care is needed.
Andrew Ruble - Replica
I agree with Andrew and Joes. I also found that the trickiest part was to pull the tap back when reinstalling the new battery. A special hint at this point in the guide would be nice.
Alexander Kluge -
This is the tricky part if there is one. Just pull back towards the battery and not up.
Joe Wasser - Replica
hello there, My macbook air does not recognize a battery connected, anymore.
It looks like I damaged the connectors while trying to connect the battery back, although it does not look damaged. I must say, I tried a little force to squeeze the connector in the middle instead of the edge. May have damaged the connector ?
Once, after this, the MBA recognized my battery when pressed the connectors edge to the pins on the board. However, this did not last long and my MBA does not recognize the battery anymore. Any solutions on how I can fix this ? Please help.
Samy Palaniappan - Replica
Had the same issue where my Macbook did not recognize the battery on the first try. I opened it back up and re-seated the connector and that fixed the problem. That particular connector does not seem to have a positive engagement. It does not appear to seat all the way down. It’s charging now and I hope it will remain stable and connected as I travel.
Paul Tornatta - Replica
Remove the following five screws securing the battery to the upper case:
  • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
Les couleurs ne me semblent pas justes.
drixe - Replica
The screw heads are made of a soft butter like chinese metal and will easily get f*cked up. take care when reinstalling to not mess them up.
John Hamilton - Replica
les couleur sont justes; die rot markierten Schrauben oben und mitte sind länger als die unteren.
I had used the P5 driver there, too (just gently put the bit into the screws and see that’ll fit.
jmhoraze - Replica
When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
  • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Quick note about the replacement battery, if you bought from iFixit and the battery sections have a thin film over them, peel them off. They're to protect the battery during transit, and if you leave them on they might cause heating issues.
Here is a link to my question about it: Replacement battery has thin film on each section do I need to remove? plus, I just got an email from iFixit customer support that it needs to be removed.
dpchoung - Replica
thank you for the help! I installed the proper batt properly following the advice from here;-) Mahalo from Hawaii-
zzzikaikazzz - Replica
Does replacement battery for Macbook Air 13" Mid 2012 works with Mac OS Sierra 10.12.3 and up?
Benny Forsberg - Replica
I installed the battery (OEM Apple) for the Mac Air 2013 throygh 2015:
1. the battery for the Mac Air 2012 throygh 2015 was stated to may have compatibility problems;
2. lesser price;
no problems with macOS Sierra.
jmhoraze - Replica
Replaced it in no time! Thank you and cheers from Slovenia (that’s the one who beat you in hockey few days ago
Mark Ogner - Replica
Linea Traguardo
Altre 382 persone hanno completato questa guida.
Done! Now my Macbook Air has a new lease on life! I travel a lot and need good battery life on my Macbook so that I can work on flights, work throughout the day in meetings, do presentations etc.,
I ordered the battery and a pentelobe screwdriver from iFixit - they arrived quickly and as as promised in South Africa. The replacement took just a few minutes. The guide was very helpful and easy to follow. Now I have 6 hours of battery life again (or maybe a few minutes less ;-)
Thanks guys. I am very happy!
digitaldion - Replica
@digitaldion, Could you share what is time on a single charge now, after almost a year of active(?) use?
yurkennis -
I had spilled Iced Tea all over my new laptop. Soaked it in rice, but it only would work when it was plugged in. I read replacing the battery would fix it. Ordered the battery...came in 2 days, and I used the repair guide. Worked with 100% success and now my laptop runs like it's brand new.
Zane Dunnings - Replica
Did it! In less then 4 minutes. One extra tip: when you remove the screws, put them backwards on the table in the same pattern as you took them out. It saves time and avoids frustration :-) Thanks iFixit!
rkamphuis - Replica
Done! That was actually quite easy; I can't believe how easy it was to do. When I ordered the battery I also ordered the iFixit 54 Bit Driver Kit and I have to say that I will likely never have to buy any screwdrivers again for any computer related fix-ups I have to do. Thanks!
Berge - Replica
Just did it! The guide made the job really simple. I had absolutely no problem during the process. It is just as easy as it seems! Thanks, iFixit!
Hugo - Replica
super easy job!
ian - Replica
I changed the battery. It was very esay. However the MBA has now become very very slow. Can anyone explain this?
Michael Iversen - Replica
It's because incompatible battery model. It requires A1405.
Denis Rozhnev -
Replaced the new battery with my old one. Now everything works as normal again. What is this about. Please notice that the new battey is an original Apple battey - not a copy product.
How can you be sure it is original?
yurkennis -
I suspect they just re-use the original apple battery trays and put third party battery packs in them. The two batteries I ordered had Apple trays, but one was in a sealed box and the other box had no seal with a hand-written sticker on the battery tray. Plus, there was wear on the battery tray screw holes which tells me they have been used before.
Munky -
The replacement itself was easy enough, but it did not solve my problem - any advice would be greatly appreciated!
I have a Macbook Air 13" mid 2011, the battery only got to 121 cycles before it stopped holding a charge at all and I could only use the laptop when plugged into the power adapter. The battery status says "Not Charging" and the adapter status light does not glow when connected (it does function normally when plugged into any other computer, so the adapter is not the issue). The second it becomes disconnected the computer shuts down.
I just replaced the battery, one I ordered from iFixIt and the computer recognizes it, but it says cycle count: 0 and condition: replace now.
Charge Information:
Charge Remaining (mAh): 2545
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6620
Health Information:
Cycle Count: 0
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7575
I'm at a total loss for what to do next to solve this problem. Any ideas?
crystalh - Replica
Check if the MagSafe port on your MacBook is intact — the small middle prong which is responsible for detecting and identifying the charger might be damaged. If it can't identify the charger, it will resort to only powering your laptop (as long as the other prongs work), but not charging it. As soon as you disconnect it, it shuts down because the battery is drained.
rale09 -
Super easy replacement job, and now my battery is like brand new again!
LeonC - Replica
Don't forget the Torx T5!
I already had a Torx set, so only bought the P5 driver, but turns out my set only went down to T6 :-(
Brian Candler - Replica
The first battery I received was faulty - it kept suddenly cutting out while in use - but iFixit were brilliant in sending a replacement immediately.
Hint: if after changing the battery your Macbook doesn't "bong" when it powers on (and you'd like to to!) then you can fix this by resetting the PRAM. See https://discussions.apple.com/docs/DOC-3...
Brian Candler -
Very great guide... coupled with the purchase of screwdriver / batter... phenomenal!
Thank you iFixIt!
Brendan Roche - Replica
Worked suberb! Thumbs up for the guide and the new battery!
robertbadas - Replica
Delivery and replacement were fast and easy. After booting up I checked the new battery with Coconut Battery and found the load cycles at 1 which was what I expected. The age of the battery was indicated as 37 months old and thus older than my MacBook Air. That's not what I expected.
Don't batteries get old from just lying around?
Skyynet - Replica
Am I the only one having trouble getting the screws out?
patrickdidomenico - Replica
My battery screws are the 6 pointed star ones, not the 5 pointed. Maybe you have the same?
effie -
The Ifixit P5 Pentalobe screw driver worked great to remove the Loctite cemented 51 PR case screws. The 5 battery screws are T5 Torx 6 pointed screws.
Cody Morgan -
I just did this repair, and it went very smoothly. The only problem I had with the instructions were that the screws on the battery were not the same 5-pointed stars as the one on the case. My battery has 6 pointed star screws. Luckily, I have both screwdrivers so this wasn't an issue. My connector also looked a bit different than the one in the photo, so maybe my laptop came from a different batch...?
effie - Replica
Maybe they edited the instructions, but as they are written today, the interior battery screws are torx and different from the case screws.
ethicalpaul -
Apple says these batteries need to be calibrated by an Apple technician and that's why replacement should be entrusted to Apple only. Does anyone know what Apple's pre-calibration process entails?
Julianps - Replica
I'm not saying that I know this for a fact concerning the Apple batteries, but often with Lithium (and this applies to the iPhone as well), draining the battery to 0, then giving it a full charge is basically the calibration.
john -
Well that was easy. Ordered the kit from ifixit. Took about 20 mins to take apart and change the battery. All good.
Lee
lee19apgar - Replica
Just completed my battery replacement and everything is working perfectly (with currently several hours of use). When removing the screws, I found it a little difficult using the iFixit brand "P5 Pentalobe Screwdriver". This is the screwdriver with the yellow handle. It felt as though it didn't actually enter the screw holes and was just barely fitting into it. I haven't used it, but I recommend the $11-12 one, especially if you plan on performing this procedure on other macbooks.
christianchew62 - Replica
Success!
Battery Guard details before->after http://fs2.directupload.net/images/15082...
Thank you iFixit
Michael Seitz - Replica
Ordered the battery and two screwdrivers linked from this page. The screws weren't laid out exactly as in the guide, but I did end up needing both screwdrivers. The replacement went pretty quick, but afterwards the battery status was being shown as "Condition: Replace Now" and was not charging. I did an SMC reset, which did not help. I then opened it back up and pressed on the parts mentioned in MacBook Air 13" Mid 2011 I/O Board Replacement to make sure they were seated correctly, in addition to plugging and unplugging the battery. Afterwards, seems to be working correctly, thankfully.
yaneeka - Replica
Was very easy!! Remember to blow off your dusty fan when you're in there, it will cool down your mac considerably.
lesveur - Replica
Super easy agree - the only thing that i was a bit tenuous on was the Pentalobe screws because the screw driver i bought from you barely fit into the screw recess - sketchy can not tell if it was a poor tool or that was the way it was suppose to be.
andy
andrew keller - Replica
Did anyone had the following problem: after changing the battery, closing the MacBook Air, it's switching on when the charger is plugged, but the keyboard (including the on/off key) is not working any more and the fans are turning high speed?
Then, it's impossible to switch it off (as keyboard seems not to be recognised), neither to reboot or reinitiate SMC, etc...
Thanks by advance
alainjoubert - Replica
Thank You, I did it!!!
Celeste Fontanez - Replica
Super easy. Took me < 10 mins.
Thanks so much for the excellent guide.
Shahid Hussain - Replica
Simple, easy, 5 minutes, but what a great outcome! Same battery since 2012. Now my Air feels new again!
Thanks for the tutorial.
cheers
ekoh
ekoh dubois - Replica
Easy repair...thanks!
Chance Hope - Replica
Easy install. Took me less than 10 minutes with the right tools I ordered in a kit separately from Ifixit.
Jon Allen McCarty - Replica
Super erklärt, es war wirklich einfach! Danke an den Autor! Und Danke an ifixit!
Arno Hartmann - Replica
hello ifixit
I need a little help
I am living in middle east I have MacBook air 13" A1370 I need to change the battery but I cant find it here it is available for mac book Air 11"
so can I fit 11"s battery to 13" mac?
please help
drift_king669 - Replica
Excellent guide! It took me roughly 20 min, but only because I was extremely cautious.
Alberto - Replica
Worked magnificently! Just a hint: on the way back I found it easier to do first 3 and then 5
Alberto - Replica
Do we remove the plastic cover the 4 lithium batteries?
Kevin Jose - Replica
Are we supposed to remove the plastic off the batteries??
letstryandsee - Replica
I did remove it, as the original battery didn't had these plastic sheets over the li-ion cells. I figured it serves as an additional safeguard against accidental punctures in the cells during transit.
My advice: be extra careful while peeling the plastic sheets, as the adhesive is super-strong, and you definitely don't want to bend the battery cells!
Fabricio -
This is easy! I have no idea why they marked it moderate. Buy the tools they sell. Buy the battery from them and do it yourself. Much cheaper and much easier than anywhere else. Did I mention it is easy? Just make sure you follow the instruction on pulling the battery cable and it will be EASY.
I was looking for this project for a long time. Finally all parts were available in EU iFixit store, I was impressed delivery only took 2 days, thanks for Haribo candies ;). Replacement took no longer than 15 mins and now my Macbook Air is like it was just put out of the box which was 5 years ago. I measured average time use, with old batter (1144 cycle count) it was around 1:45 at max, now I am running for 2:22 hours at 50% while installing apps, listening music and so on (did High Sierra install while during this time). My expectation that it will be around 5hrs heavy-medium use and perhaps even close to 6hrs doing light work.
Battery before after, http://www.directupload.net/file/d/4883/...
Maros Kukan - Replica
I had so much fun! Thank you ifixit, for empowering me to do this job cheaper than my local Mac store (who would have probably lost a couple more screws like they did last time, anyway). Shipping was fast and allowed me to hit a work deadline. Next time I get in a bind, I know exactly where to go! <3
Kimberly Drew - Replica
10 outta 10 !
Vincent Fiset - Replica
J ai du réinitialisé le mac pour qu il reconnaisse la batterie ouf cela marche simple défaire le contact de la batterie appuyer dix secondes sur le on off ou suppr sur un clavier US rebrancher et cela marche ouf !
TISSERAND ANNICK - Replica
I’ve replaced the battery and it powers up fine but the track pad now feels kinda “loose” does anyone else have the same problem? When hitting the very bottom of the track pad it now react to slight touch where before it was stiffer.
Basil - Replica
Same problem here. After replacing the battery the touchpad lifts up on the lower end (towards the user) and has a higher level than the case. It stands out about 0.5 to 1mm. Any solution for that @ifixit?
Tobias Marks -
After comparison to the original battery, the new one is a little bit thicker than the original one at the area underneath the touchpad. Any chance to get a better one that fits?
Tobias Marks -
@biasx Yeah that doesn’t sound right at all! Sorry for the frustration. If you bought your battery from iFixit, give the customer support team a shout and they’ll get you squared away.
Jeff Suovanen -
I have the same issue. It’s becoming annoying. Any updates?
James Lin -
I did replace the battery following all instructions above. It was easy. I connected the computer to power adaptor and the newly battery was charged to 100% without trouble. Then, I disconnected computer from power adaptor (battery was 100%) and left computer working to see how long it would take to empty battery (i.e, doing the first cycle). After 10-15 minutes, the computer crashed and lost power. I had to connect the power adaptor again (green light is on) but now the computer starts and crashes after a short while. It says that battery is not charging (is at 91%) but then crashes.
Please, any help will be welcome. What should I do?
D
Domingos Henrique - Replica
Das ist leider nicht der richtige Schraubendreher…. Hier wird der Pentalobe P5 angegeben….!! Bei dem MBA 2011 ist es ist aber der Pentalobe-Schraubendreher Größe TS4 1,2mm!! Ärgerlich…
T Bo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 102
Ultimi 7 Giorni: 670
Ultimi 30 Giorni: 2,758
Tutti i Tempi: 302,453
