LCD Screen screw threads damaged
The screw threads of LCD of my iMac mid-2010 27" damaged any possible solution to fix my problem?I tried to find one size bigger torx screws but i didnt find anything.
Questa è una buona domanda?
A heavy application of LockTite should work - you're not holding elephants, just want to keep the parts together.
If this answer is acceptable please remember return and mark it.
Thanks you for your answer but let me be more spefic not broken anything to put locktite just the screws doesnt "tighten up" anymore to screw threads.
Right - you need a sort of "sleeve" or anchor. You could use the locktite (don't over tighten) or make a shim.
Thanks a lot you have been very helpful i use locktite blue which did the job wonderfully and most important the result is not "permanent" means i could open the mac if it needs service in the future.
That's why I recommended locktite over superglue.
Parti & Attrezzi Popolari
Acquista tuttiUltime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 559
