Salta al contenuto principale
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
LCD Screen screw threads damaged
The screw threads of LCD of my iMac mid-2010 27" damaged any possible solution to fix my problem?I tried to find one size bigger torx screws but i didnt find anything.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
A heavy application of LockTite should work - you're not holding elephants, just want to keep the parts together.
If this answer is acceptable please remember return and mark it.
Punteggio 0
4 Commenti:
Thanks you for your answer but let me be more spefic not broken anything to put locktite just the screws doesnt "tighten up" anymore to screw threads.
da
Right - you need a sort of "sleeve" or anchor. You could use the locktite (don't over tighten) or make a shim.
da
Thanks a lot you have been very helpful i use locktite blue which did the job wonderfully and most important the result is not "permanent" means i could open the mac if it needs service in the future.
da
That's why I recommended locktite over superglue.
da
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
poseidonas83 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 559
