Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
Should I remove SSD in my situation?
Hi there.
I want replace my broken screen and first of all I should remove the display. So I stopped at this step: MacBook Air 11" Mid 2011 Display Assembly Replacement cause I have broken thread of screw. Its bad I know but I do not want replace SSD. So my question: Can I continue this guide without remove of SSD?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It appears to me that you can continue with the guide without removing the card. Just be sure to observe ESD protocols when working on your machine, read through this before working on your machine: Electrostatic discharge (ESD) control
Punteggio 2
1 Commento:
Thanks a lot. But I found problem with this: in next steps I should remove cooler but I can't do that without remove SSD, because screw hidden under SSD :)
da
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Maxim sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 958
