Salta al contenuto principale
1.83 GHz Core Duo or 1.83, 2, or 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
How can I remove line on my screen?
How can I remove lines on my screen? Am using iMac 5,1 17 2006 products, the lines are verticals and very thin and it keeps on multiply with different colours namely blue, yellow, and pink the lines merges to black any time I put on the pc for about five to ten minutes, the lines keeps remaining on the screen.
Questa è una buona domanda?
Punteggio 1
2 Commenti
More information is needed. What computer--what screen--where is the line--how does it run (up&down--left&right)--how big is it and so on. Ralph
da
Am using Brobook G4 17", when I fix the memory on the slot it doesn't work but at times it works, what is causing the problem, because I've fix in new memory and still it doesn't work.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Connect the iMac to an external monitor to check if the problem is a graphic card problem or a LCD panel issue. A normal video signal on the external monitor would lead to a LCD display issue related to a bad LVDS cable or bad LCD panel.
Punteggio 1
Parti e strumenti popolari
Acquista tutti
Aggiungi la tua risposta
Johnson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,675
