Salta al contenuto principale
Can I replace the LCD display (not the entire top assembly)
I am having flickering problems on the entire right portion of the screen (about 2 inches) on my A1237. Nothing showed up on Apple's genius bar diagnostic. I think the problem is in the display itself. Is it possible to replace just the display LCD or can I only get the entire top assembly? Thanks. David
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
You can see how to separate the LED display from the display assembly here on the complete teardown:
MacBook Air Models A1237 and A1304 Teardown
Be sure to check out any tools you may need to complete the process such as an anti-static mat that will keep electronics safe to the easy-to-use pro-tech base toolkit :)
Punteggio 1
Aggiungi la tua risposta
david sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 735
