Salta al contenuto principale
The Lenovo ThinkPad X1 Tablet (3rd Gen) is a 13-inch laptop computer that can switch between tablet, laptop, and canvas, like a Microsoft Surface Pro.
Touchscreen Not Working in Windows 11
After I upgraded to Windows 11, the touchscreen doesn't work anymore. How to fix it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi @raydyliacco
Check the status of the touchscreen in Device Manager to see if it is installed correctly or whether it is disabled etc.
Go to Device Manager > Human Interface Devices > HID Compliant touch screen.
  • If there's a red cross next to the entry, right click on the entry and select Enable device. Then right click on the listing again and select Properties and check in the General tab, that it shows "this device in working properly" in the device status box.
  • If there's a yellow exclamation mark next to the entry, right click on the entry and select Update drivers and follow the prompts. You need to be online for this to work.
  • If there's no Compliant touch screen entry shown, click on Device Manager > View > Show hidden devices and search through the categories to see if you can find it listed anywhere in Device Manager.
To get to Device Manager in Win11, press the Win key + x key (both together) and click on the Device Manager link in the menu box that opens.
Punteggio 0
Aggiungi la tua risposta
Ray Dy Liacco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 43
Tutti i Tempi: 78
