Salta al contenuto principale
Conosciuta come ''PS2'', è una console per videogiochi di sesta generazione rilasciata per la prima volta da Sony in Giappone nel marzo 2000. Negli Stati Uniti è stata introdotta nel 2000 con il modello SCPH-30000. La riparazione di questo dispositivo richiede solo strumenti comuni, ma può essere complicata.
Pierced Power Button cable for the PS2 Model SCPH-39001
Basically, I found a PS2 Fat lying around my home, I tried turning it on to see if it worked, and it didn't turn on. Turns out the (what I suppose is the power cable) is pierced.
Is there any issue if I buy a generic ribbon for replacement? Or do I need a specific cable to fix the issue?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi there!
You do need to buy the correct specific one.
Usually it's 7 pin. Please check before you order that it's the right one!
You can find them here: https://www.ebay.com/sch/i.html?_nkw=ps2...
Please let us know how it goes!
Punteggio 2
2 Commenti:
Hi there, my personal issue is that I live outside the US, so buying it from eBay or Amazon comes with a hefty shipment price tag.
Looking through my local version of those two sites, I found this one:
https://articulo.mercadolibre.com.co/MCO...
Since both the eBay one and the Mercado Libre one are pretty much the same (both are 25cm long and have 7 pins) I guess they're the same, but it's still worth to double-check.
da
Hi!
Does your PS2 model type matches there? If yes, I think you need that one. Both are the same size and both are the 7 pin one, so I think your all good! Would give that a try :)!
da
Parti e strumenti correlati
Aggiungi la tua risposta
sweaty gus sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 29
