Salta al contenuto principale
The Galaxy A14 is a low-end slate Android smartphone released by Samsung in January 2023 as a successor to the Samsung Galaxy A13. Identifiable by model number SM-A145 (followed by version/carrier-specific character.
20 Domande Visualizza tutte
How Can it be turned on without the power on button
The power on button is broken. Is there any other way that it can be turned on?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @galvinjaiki
Try the following and check if it works on your model.
You will need a working computer (Windows or Mac) and the phone's power/data cable.
Turn on the computer and then once it has turned on fully etc, connect the phone's power/data cable to it only at this stage.
Then on the phone press and hold the Volume Up and Down buttons (both together) and then plug the power/data cable into the phone.
Hopefully within a few seconds the phone should turn on with a message stating that the firmware upgrade cannot be performed or similar.
When this happens, release both the Volume buttons and then press and hold the Volume Down button.
The phone should restart and start to turn on. When this happens remove the power/data cable from the phone and release the Volume Down button.
Punteggio 1
Aggiungi la tua risposta
Galvin Jaiki sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 17
Tutti i Tempi: 35
