Salta al contenuto principale
Repair and disassembly guides for Acer TravelMate laptops.
Orange light blinking only when plugged in
I recently bought an acer travelmate 4003lci, I left it to charge over night but nothing changed, it only blinks rapidly when I try to power it on only when plugged in, it didn’t come with an HDD, I’m using a 12 volt charger while it needs 19
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @titan62466
The charging circuit in the laptop is designed to work with 19V on the input and not 12V
Try using a charger with the appropriate voltage and check.
Punteggio 2
1 Commento:
Thank you so much !!!
That didn’t cross my mind !
You saved me from buying a new battery !
da
Parti e strumenti correlati
Acquista tutti
Aggiungi la tua risposta
Titan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 39
