Salta al contenuto principale
Laptop Shutdown Automatically at 30%
HI! my laptop keeps shutting down at 30% automatically without any notification. But when I plug in the charger and start it it starts the charging from ht e 30%..any solution quick as fast as you can
Questa è una buona domanda?
Punteggio 0
1 Commento
@muhammadad71091 if calibrating the battery doesn't work, it's time to replace the battery.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
I'm pretty sure that this is actually an issue with your battery's calibration. Try this: Battery Calibration
Punteggio 1
Check the settings, its most likely a laptop battery setting.
Punteggio 0
Aggiungi la tua risposta
Muhammad Adeem Amjad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 27
