Salta al contenuto principale
La variante solo Wi-Fi dell'iPad di quinta generazione è stata rilasciata nel mese di marzo del 2017. Disponibile con tagli di memoria pari a 32 o 128 GB, presenta un display Retina da 9,7" e il processore A9 a 64-bit.
Number 2 on each screen that is permanent
I replaced the digitizer on a 5th gen iPad with a new one from ifixit, but now there seems to be a number 2 on the screen that is up near the top right near the battery indicator. it is sideways and very small, and is on each screen in the same spot, even when watching videos.
Questa è una buona domanda?
Punteggio 0
1 Commento
Amazing, I couldn't even tell that there was a plastic film on the digitizer. Thank you so much, that was it.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi,
When replacing an LCD or Touch glass both come with this protection and it’s easy to miss removing one.
The touch glass has one either side and the LCD one is sometimes cut so close to the edge that it looks like it’s part of the LCD and not there.
These protective films can have small manufacturers stickers or markings on them that are not always easy to see.
I’m guessing that your problem is one of the plastic films haven’t been removed.
Hope this helps
Punteggio 1
Parti & Attrezzi Popolari
Acquista tutti
Aggiungi la tua risposta
Mike Joyce sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 27
