Salta al contenuto principale
A sanitary disposal device for human waste. No plumber necessary! Fixing a toilet is more straightforward than many people think.
20 Domande Visualizza tutte
Two toilets acting wierd
I live in a 60s one level home with two bathrooms. One toilet is bubbling. I go in and there is like hardly any water in the bowl. The other toilet has overflowed twice. With no one using it. Help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @barmstrong
Low water level in a toilet bowl is indicative of a partially blocked sewer pipe or air vent.
If the other toilet is filling instead of draining this also indicates a blockage in the pipes somewhere.
You could try clearing it using a plunger.
If still no good then you may have to try using some other options¹ or calling a plumber as they should have the necessary equipment to clear drains.
¹Option shown only to show example of what you can use - not an endorsement of the service.
Punteggio 1
Aggiungi la tua risposta
Beth Armstrong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 22
