Salta al contenuto principale
Repair and disassembly information for Samsung's flagship S20 FE Android smartphone, released in October of 2020. Identified by model numbers SM-G780F or SM-G780F/DSM
SIM problem SM-G780G (s20 fe 4g)
I have a problem with call reception, data connection, and SMS, that is, everything about the SIM. Strangely, however, the SIM signal bar shows that there is coverage. I have tried doing a hard reset and reinstalling the firmware from scratch, but to no avail. The SIM works perfectly on another device, so there are no field problems, nor is airplane mode on. I will preface this with the fact that the phone suffered a heavy bump, although it has no superficial damage. Once disassembled, I checked all the antennas, which all appear to be properly connected. The only thing that jumped out at me were bulges on the motherboard cover, top right.
Screenshot 1: As you can see, the call and message options are not selectable (Settings / Connections / SIM Management)
Screenshot 2: In the SIM supplementary services settings it detects an inability to retrieve data (phone app / Settings / Supplementary Services)
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
@riccardorusso it might just be the SIM card reader or the SIM card circuitry. We really would need to see that damage. Your pictures did not get attached to your Question. Use this guide https://it.ifixit.com/Guida/Aggiungere+i... to add pictures. you can only add pictures to Answers and to your original Question.
Translate
@riccardorusso potrebbe essere solo il lettore di schede SIM o il circuito della scheda SIM. Avremmo bisogno di vedere il danno. Le tue immagini non sono state allegate alla tua domanda. Usa questa guida https://it.ifixit.com/Guida/Aggiungere+i... per aggiungere immagini. Puoi aggiungere immagini solo alle risposte e alla tua domanda originale.
Punteggio 0
Aggiungi la tua risposta
Riccardo sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 4
Tutti i Tempi: 83
