Salta al contenuto principale
Lo smartphone al top di gamma di Apple per il 2020. Annunciato il 13 ottobre e rilasciato il 13 novembre, l'iPhone 12 Pro Max vanta uno schermo OLED da 6,7", un sistema di fotocamere triplo dotato di LiDAR e connettività 5G. È il successore dell'iPhone 11 Pro Max.
20 Domande Visualizza tutte
Says cellular is unavailable and my friends phone won't update
My friends phone got ran over by a car and the screen is destroyed but it's fixed but says cellular needs an update and when try to update it gets stuck on verifying update. I really wanna get the cellular working.
Questa è una buona domanda?
Punteggio 0
1 Commento
Have you tried to update with iTunes with a cable connected to the computer?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi,
Based on the information you provided, you will need professional help to fix your iPhone 12 Pro Max. The motherboard is affected by physical damage. (this is not a software problem)
iPhone 12 Pro Max has a sandwich motherboard. The top board is responsible for UI, and the bottom board is for communications. If the top board does not detect the bottom board, your iPhone will report a cellular error. The top and bottom boards are joined together with a connecting layer. As the iPhone was run over by a car, most likely, the connections are broken/disconnected.
To confirm this problem, go to settings/general/about and check Wi-Fi, Bluetooth ID, and Modem firmware. If any of these are missing, then it's a hardware problem.
BR
Francis
CelMetro
Punteggio 2
Aggiungi la tua risposta
ATVB1 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 26
