Salta al contenuto principale
Il Huawei Watch 3 è il primo orologio di Huawei che funziona con il loro HarmonyOS 2. Le sue principali caratteristiche sono uno schermo AMOLED da 1.43", eSIM, sensori della frequenza cardiaca e SpO2 e una corona girevole, fornendo fino a 14 giorni di vita della batteria.
Power button is not working
Hi, there guide to change and replace Huawei Watch 3 crown(power button). Button pressing is not working.
Questa è una buona domanda?
Punteggio 1
1 Commento:
Is your button clicking? Did you get it fixed?
da
Aggiungi un commento
1 Risposta
Hi,
There is an excellent video on YouTube by GOODTIMES TECH that shows an identical issue with Huawei watch which shows the problem being related to a plastic piece that is worn causing the power button to not activate the switch.
The audio isn’t very clear but very easy to follow and shows successful remedy for the button issue.
You can find it here:
https://m.youtube.com/watch?v=e-_h8R2IXc...
If you’re battery isn’t dead this will more than likely be the issue with your watch.
cheers
Punteggio 0
1 Commento:
My button clicks good. No worn plastic piece. Maybe corrosion underneath the clicking part onto the PCB ribbon behind.. Even some electronic contact liquid cleaner didn't have any effect.
It still shows the time, and sensors are right, but can't launch any app anymore.
da
Aggiungi la tua risposta
Tuomas Mäkinen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 75
Tutti i Tempi: 400
