Why is my ignition cap blowing off spark plug
why is ignition cap blowing off spark plug
Questa è una buona domanda?
Ottieni un rapido accesso alle guide, ai componenti e alle risposte per i tuoi dispositivi
Either it wasn't screwed in properly in the first place (how long ago was it changed?) and didn't have enough thread purchase to hold it in or it was screwed in too tight which can cause the plug to malfunction and break down and blow out.
You didn't specify the engine size but assume it's a 2.2L so 18N*m (13Ft*lbs force) is the torque value used for tightening spark plugs.
Also try not to install plugs when the engine is still hot as it may cause the plug not to be seated properly/twist etc as the engine cools.
In the end you can only try installing a new plug (with the correct torque) and check if it occurs again
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 17
Hi @michaelnug94590
What is the year model and engine size of the vehicle?
da jayeff
@jayeff is a 1999 4 cylinder
da michael nugent
my spark plug blew out. hoping threads are ok
da michael nugent
