Why is my bluetooth range shortened
My laptop's Bluetooth only connects when the Gadgets are very close to the screen, can someone suggest how to fix it??
Questa è una buona domanda?
Hi @sakshamjha
Do you have the same problem when connecting to WiFi?
If so, since both the WiFi and the BT use the same antennas there may be a problem with the antenna connection (loose?) to the WiFi/BT card.
Here's the hardware maintenance manual for the laptop.
Go to p.58 to view the procedure to remove the WiFi card.
You don't have to remove the card, just check that both the antenna cables are securely connected to it - see image on p.59.
i have a laptop so i believe there so there is no antennas in my laptop(i am not very clear on this) but still I'll check it out
You selected a Lenovo V14 G2-ITL laptop as the one that you're asking about so I linked the manual to show you where to check the antennas!
The laptop must have antennas otherwise the signal range would be too short to be able to use the WiFi/BT effectively.
Parti e strumenti correlati
Acquista tuttiUltime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 40
