Salta al contenuto principale
Canon PowerShot SD4500 IS 10 MP CMOS 10x Optical Image Stabilized Zoom with Full-HD Video and 3.0-Inch LCD Digital Camera.
Lens error, will shutdown automatically
I cannot use the camera, try to focus the lens but then shutdown automatically.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@ricardomillan lens errors are common with digital cameras. First try to fix it by using some of the advise listed on here. If none of those work, you may have to consider replacing the lens. The issue with repairing it, is that parts are usually not available to repair the lens. The problem now is that you will have to be a Pathfinder. There are no guides or teardown for this camera. You are going to have to go solo on that one. The only thing I would suggest is that you use one of the other SD PowerShot guides. Luckily all of them share enough similarities that those guides will be helpful. Just move slowly and methodically and you should be ok.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Punteggio 0
Aggiungi la tua risposta
Ricardo Millan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 36
