Salta al contenuto principale
How to update BIOS of C50-B?
I cannot update BIOS from 1.30 to5.10. Please help me.
Questa è una buona domanda?
Punteggio 0
1 Commento
I had disabled secure boot and enabled cam boot.Still it shows error,ec id check failed
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
What have you tried so far?
Did you read this?
Toshiba Satellite C50 BIOS update
Secure boot and CSM boot setting is important.
The boot menu key is either F12 or F2.
Punteggio 2
21 Commenti:
I disabled secure boot and enabled csm boot,still no response,It shows ec id check failed
da
Hi @joeljoseph70261
1.) Did you reset the BIOS by removing/disconnecting the CMOS battery? It could be corrupted.
2.) https://support.dynabook.com/
and type in your serial number just to double check you have the correct BIOS version for your exact laptop model.
3.) Did you format the USB flash drive with FAT 32?
da
Yes I did,My model does not have CMOS battery
da
@joeljoseph70261
There is a CMOS battery on the motherboard.
It is a rechargeable battery that is soldered onto the board.
Look for JRTC component on the board
You can also clear the cmos (BIOS) by short circuit on jumper pads JP1 & 2 near the ram door, for about 10 seconds
da
Does csm os can help update bios
da
Mostra altri 16 commenti
Parti e strumenti popolari
Acquista tutti
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=oKpBB31R...
Punteggio 0
Aggiungi la tua risposta
Joel Joseph sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 37
Tutti i Tempi: 485
