Salta al contenuto principale
The Wii Remote is the original, primary controller for the Nintendo Wii game console released November 19, 2006. The model number for the original Wii Remote is RVL- 003.
20 Domande Visualizza tutte
1 button slightly unresponsive. Cleaning had no effect.
The 1 button on my Wii remote doesn't respond to soft presses, only hard presses. I opened and cleaned it with isopropyl alcohol and cotton swabs to no effect. There was also no visible corrosion or dirt.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
Well, the only left to do is to clean it (usually this always work). The only thing left to do now is to replace the rubber and test it again, if this failed, then use some sand paper and carefully go over the button circuit (only for "1").
If this failed as well, then it's motherboard related and need to be replaced.
Punteggio 1
Aggiungi la tua risposta
Cych sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 108
