Salta al contenuto principale
Repair guides and support for Windows 7 OS, an operating system released by Microsoft in 2009.
Windows 7 screen resolution problem
I have an all-in one PC that had 32- bit Windows 7. But once I upgraded to the 64- bit version,the only available screen resolutions were 800x600 and 1024x768. MS-A923
Questa è una buona domanda?
Punteggio 1
2 Commenti
@pawelc you may need the 64bit display driver.
da
It might just be simpler to upgrade to Windows 10? It handles drivers much better than W7.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @pawelc
What resolutions were you getting with Win 7 32-bit?
According to the specifications, the AIO uses onboard video i.e. Intel Media Accelerator 3150 integrated in the Intel D525 CPU.
This only supports resolutions of up to 1366 x 768 for internal LVDS connections.
This is also the native resolution of the AIO display.
Have you got the Win 7 64-bit graphics drivers (example only) installed, to see if you can get to 1366 x 768 resolution?
Punteggio 2
3 Commenti:
@jayeff 800 x 600, 1024 x 768 even though it's widescreen. But it gets stretched out
da
@pawelc Have you installed the drivers?
da
@thequacker Yes and it worked!
da
Parti e strumenti correlati
Aggiungi la tua risposta
Pawel C sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 175
