Salta al contenuto principale
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
How to put belt on the mower deck
how dose the belt go on the mower deck
Questa è una buona domanda?
Punteggio 7
7 Commenti
how to put blade belt on modile 917289031.
da
What about 3 belt craftsman.I have 2 ride mowers one is 2 belt other is 3belt ?? The deck belt patterns are different
da
is this for a deck on a 7000 series 42" cut mower?
da
This is. For the 2ooo series. Model 247.288852. Serial # 1A192B10186
da
46 inch deck
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Risposta Più Utile
Mike,
Usually there are two belts. One goes around two pulleys, a front pulley under the motor and one on the mower deck. Additionally, there is usually a spring tensioner pulley that rides against the belt to allow it to work and for ease of routing.
The second belt goes under the first belt and is routed on a common pulley with the drive belt and both (or all three) of the mower blade pulleys.
Here is a crazy looking exploded view of a craftsman mower deck
And here is a better diagram of it all put together. I think you can get an idea of belt routing out of this one:
Punteggio 2
2 Commenti:
Do I have to bend the metal bracket that keeps belt from slipping off pulley to put a new belt on. The belt will not go on pulley unless I do bend it back.
da
The bracket that holds the blade belt on the pulley is stable and will not move. How do I get the belt on pulley without bending it
da
Preparati per le riparazioni future
Aggiungi la tua risposta
mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 26
Ultimi 7 Giorni: 112
Ultimi 30 Giorni: 540
Tutti i Tempi: 66,625
