Salta al contenuto principale
Lanciato a maggio 2020, il MacBook Pro da 13" ha dei processori quad-core Intel di ottava generazione Core i5 e i7, e grafica integrata Intel Iris Plus 645. (Modello A2289/EMC3456 con due porte Thunderbolt 3)
20 Domande Visualizza tutte
a vertical line exactly in the middle of the display
I have a vertical line exactly in the middle of the display. Also in a windows Bootcamp Version but not at an external monitor. I also try already resestting the smc.
Have anyone an idea?
edit:
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Oh Boy! Not good😖
The display panel its self has a collection of thin contacts along the bottom edge. What can happen is during the manufacturing process one of the connector breaks free we call this a TAB error. If its more than one line it could be the Chin plate at the bottom of the display got smashed in so one of the glass shards cut the ribbon cable.
Sadly, you will need a new display assembly to fix it or just live with it. I would visit an Apple Store if you still have warranty coverage or enrolled in AppleCare as that would be a free repair. Otherwise it's a bit of $$$
Punteggio 1
4 Commenti:
I added a picture in my original post. I think it is more than one line?!
da
@dernerl - Sadly it does!
Are you using a clip-on shell or glued-on camera cover? They both can press on the display panel in such a way as to damage it as your image shows.
Apple even put out a warning about these as they tightened the air gap between the case and lid
da
no, nothing like that. I already live with that like a year.
In any case, thank you very much for the technical background to my error!
da
@dernerl - If your set, please accept the answer - Thanks!
da
Aggiungi la tua risposta
Daniel Hug sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 102
