Salta al contenuto principale
Repair and disassembly information for Google's Pixel 6 smartphone, released in October 2021. Identified by model number GB7N6 and G9S9B16.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
Punteggio 0
3 Commenti:
Did old screen work? I have the same issue touch is not working even though there is no crack
da
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
da
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
da
Preparati per le riparazioni future
Acquista tutti
Aggiungi la tua risposta
Mike Meller sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,636
