Salta al contenuto principale
Informazioni su riparazione e smontaggio per lo smartphone Google Pixel 6, lanciato nell'ottobre 2021. Identificato dai numeri di modello GB7N6 e G9S9B16.
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
Punteggio 0
3 Commenti:
Did old screen work? I have the same issue touch is not working even though there is no crack
da
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
da
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
da
Aggiungi la tua risposta
Mike Meller sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 2,327
