Salta al contenuto principale
Modello A1311 / Metà 2010 / Processore Core i3 da 3,06 e 3,2 GHz o Core i5 da 3,6 GHz
Any problems with the temperature sensor when replacing the HDD?
Hi,
I was reading a lot about upgrading the HDD but I am confused about the bit with the temperature sensor.
My understanding was that replacing the HDD with a new (larger) HDD will lead to the new HDDs fans running on full power because the temperature sensor cant be attached to the new drive.
Is there a way of avoiding that problem and install a larger HDD without having to deal with the temperature sensor issue?
Thanks.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You'll need to get your drive directly from Apple to avoid the temperature sensor issues.
Punteggio 3
Preparati per le riparazioni future
Acquista tutti
I contacted an authorised Apple Service Provider and they said they could install a 2TB HDD for about 500 EUR.
Given that I paid around 1000 EUR for my iMac, I think that is insane!
The answer to my problem seems to be HDD Fan Control.
Punteggio 0
Aggiungi la tua risposta
richard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 682
