Salta al contenuto principale
Linea delle stampanti HP a getto di inchiostro
Tips for printer optimization?
Hi, my dad has an HP Officejet Pro 8020 series printer, and he uses it a lot. Does anyone have any tips for getting more usage out of each ink cartridge (i.e. bypassing the sensor in the cartridges that falsely reports that they are out of ink)? I'm completely fine with tweaking the firmware, or whatever I have to do, but I just don't really know what specifically I would need to do. Any suggestions?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi @shingle,
If your father doesn't mind having lesser "quality" prints, try printing with a lower resolution i.e. dpi setting or use the "draft" setting if that is an option.
Lower resolution means less ink is used.
Using the greyscale option also uses less colour ink if only printing black and white but uses the same amount of black
Just some ideas
Cheers
Punteggio 2
Preparati per le riparazioni future
Aggiungi la tua risposta
shingle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 83
