Salta al contenuto principale
Display LCD widescreen da 4.3’’ con processore da 333 MHz. Numero di modello PSP98510. Riparare questo dispositivo richiede cacciaviti e strumenti per fare leva.
My PSP screen is scratched?
My PSP 2000 has a big scratch on the front screen, the LCD and front case are okay, but it would help a lot if someone could make a how to on replacing front screens. thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Well, the replacement of the front screen is fairly easy. Also, you could try, if the scratch is big but not very deep, to patch it up with some Displex, Brasso or similar stuff.
I read you scratched the "Outer Shell", the plastic part covering the display. Well, a front case is a fairly inexpensive part, and you can also get some "modded" casings of different colors, or even transparent.
So you can follow this guide Sostituzione della scocca anteriore PSP 2000 and it'll take you no time.
Punteggio 1
my psp has black scratches in inner screen how can i repair it?
please tell me?
Punteggio 0
Aggiungi la tua risposta
Tomas Ibarra sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,615
