Salta al contenuto principale
This is the 8-inch version of the smaller Fire 7. It includes 1.5 GB of RAM, a faster processor, and an HD display. The Fire HD 8 was released on June 7th, 2017.
How can my tablet be fixed?
My fire HD8 tablet screen is cracked What should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
First you need to be sure the actual screen is cracked. Does it look as if ink is running down the screen when you turn it on? If not then most likely it's actually the digitizer that's cracked and you simply order a new digitizer and install it. Google will bring up a you tube video and show you the exact procedure for replacing it.
Punteggio 0
Parti e strumenti correlati
Acquista tutti
@ooleygrider here is the guide on how to replace the display assembly. It's easiest replaced as a complete assembly. Sostituzione Schermo Amazon Fire HD 8
Punteggio 0
Aggiungi la tua risposta
Ooley Grider sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 69
