Salta al contenuto principale
Repair guides and information for bread makers.
Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
Questa è una buona domanda?
Punteggio 1
3 Commenti
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
da
When I turn it on, it starts in the middle of the mixing cycle.
da
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
Punteggio 1
2 Commenti:
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
da
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
da
Parti e strumenti correlati
Aggiungi la tua risposta
Janet Schuroll sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 986
