Salta al contenuto principale
Popular clothes dryer series by Kenmore.
My dryer does not stop automatically.
The timer does not shut down the dryer automatically. You can turn it off by turning it manually clockwise.
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi @bert42849,
What is the model number of the dryer?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Does it shut off when you open the door?
Punteggio 1
2 Commenti:
No, it does not stop when you open the door. The timer does not count down to the stop point. When you turn it clockwise to the stop point everything works fine. It’s like manual mode. Only to stop it from continuing to dry.
da
yes it shuts off when i open the door
da
@johnzechnersr, without the model number of your dryer we can't be specific, but the times when I've seen this situation it's been due to the timer motor dying. The timer operates with a motor that rotates the dial very slowly, and when that motor craps out, you get this situation - everything works as long as you advance the timer by hand.
I've been able to test it by taking the timer switch out and manually wiring the timer motor up to 110V. Obviously you'll want to verify that's the correct voltage for yours before doing that. Take a marking pen and mark any random position on the timer dial, then leave the timer connected up to power for like 15 minutes. If the mark hasn't moved, you need a new timer motor.
It's a crapshoot as to whether you're going to be able to buy just the motor itself, or you'll end up having to replace the whole timer; it all depends on which model you have, since Sears used several manufacturers to build their Series 80 dryers. Again, the model information is critical for finding the right parts.
Punteggio 1
Aggiungi la tua risposta
Bert sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 101
