Salta al contenuto principale
La decima generazione del "phablet" Samsung, con stilo S Pen. Rilasciato nell'agosto 2019.
touchscreen does not work
Touch screen comes on but doesnt register touch. Is there a way to fix this?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Has anything happened to the phone recently, such as a drop, liquid exposure, firmware update, etc.?
Your phone actually has two separate digitizers; one for your finger, and one for the S-Pen. If one fails, often the other will continue working; I had a Note 4 where the S-Pen digitizer failed but the touch screen still worked.
Anyway, assuming it's a hardware failure, the cause is almost always the digitizer rather than a problem with the motherboard. The fix is to replace the entire screen, as you can't really replace those three components separately, at least not without very specialized equipment and expertise.
So you'll want to try all the software fixes you can come up with first, such as hard resets, doing a backup and full restore, etc., to make sure it's a hardware problem. After that, you'll need to replace the screen. Here's the iFixit guide to doing that on your phone.
Samsung Galaxy Note10+ Screen Replacement - iFixit Repair Guide
Unfortunately, your phone is still fairly new and prices for a new screen haven't come down a lot, so it's going to be somewhat expensive to fix. You can buy a new screen right here on iFixit, and it appears to be available in other markets such as Amazon, eBay and AliExpress.
If you buy it from iFixit, I recommend the Fix Kit, as it comes with all of the tools and adhesives needed to do the job right for a minimal cost.
Good luck; let us know what you find!
Immagine Replace a cracked or malfunctioning AMOLED display and digitizer screen compatible with the Samsung Galaxy Note10+. Includes the front glass digitizer screen and 6.8 inch AMOLED 1440x3040 Display.
Prodotto
$299.99
Punteggio 0
Aggiungi la tua risposta
Devin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 290
