Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
Domanda Chiusa
How can I fix the LCD cable connector plug?
I replaced the LCD and cable number 1 which connects the LCD to the logic board or mother board will not stay connected, sometimes it does and when it does, a blank LCD shows. If I press the connection down or hold it with my finger the connection is normal. as soon as let my finger go the cable stay connected but the LCD goes back to blank.
Any ideas how to fix this problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It's not ideal and is unlikely to work long term but try some squishy foam, like earplug foam and perhaps Blu-Tack if you jam it in the phone then close it, it MIGHT provide enough pressure to work. If not, you're up for another LCD. Or if the damage is to the Logic board you're in real trouble.
Punteggio 0
Preparati per le riparazioni future
Acquista tutti
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,824
