Salta al contenuto principale
The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
20 Domande Visualizza tutte
Second Screen not Connecting
I have purchased a dual screen but somehow cannot connect to the main screen.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Treve Dyoll what kind of dual screen? How are you planning on connecting that to the device you selected LG V60 ThinQ? Post some pictures of exactly what you purchased. We need a make/model etc. Aggiungere immagini ad una domanda
da
Aggiungi un commento
1 Risposta
Same thing here...
I Bought a second screen, due to the repair bill being almost as much. That Second screen works...
Hint:
Connect it ( second screen) to the V60, then Don't continuously connect and disconnect.... Get the little external USB adapter and charge thru that
NO excuses ... Don't make my mistake. Once working, don't disconnect it, unless you can do as I will (am) doing in the last paragraph...
Seems there is a particularly delicate connection issue between the V60 unit's connecter, and the screen.
Also the V60, even without the dual screen, will fail to charge with adequate speed due to the phone's connector..
I'm purchasing a kit to clean all the above connectors. Someone indicated this is an issue with the phone's charging port, or maybe the dual screen's port. The iPhone has the same problems.
Punteggio 0
Aggiungi la tua risposta
Treve Dyoll sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 255
