Salta al contenuto principale
Repair and disassembly guides for electronic keyboards.
Keyboard buttons won't work
Yamaha psr-82 My keyboards buttons from overall controls, accompaniment control, voice/style, sustain, auto harmony, chord memory, and song book. The only button that works is the power button. The adapter works and the keyboard keys work but everything else isn't.
Questa è una buona domanda?
Punteggio 2
1 Commento
Recently, I upgraded to a new keyboard, and it’s been a game-changer. It's not one of those big-name brands, but it’s got this solid build and each feature works like a charm. It made me realize sometimes a lesser-known brand can surprise you with quality. Maybe exploring options beyond the mainstream could lead you to a solution.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi
I don’t usually work in Yamahas but I have worked on lots of Roland machines and when the controls and button stop working but the keys work that tends to mean that the daughter board on the top half of the keyboard has a issue
I can’t say exactly what the issue is as it can’t vary from machine to machine but it should be obvious(I would look for blown components damage and corrosion),if you can’t see anything on the boards you can use this guide(linked below)if you would like:-)
Aggiungere immagini ad una domanda
Hopefully this helps
Any questions please ask
Punteggio 1
3 Commenti:
Hi @hellomacos,
It could also be something as simple as a loose cable connection to the board (at either end)
Cheers
da
Hi @jayeff
It could be that:-),it could also be a battery leak if it uses them
da
I was in a similar spot with mine—it was an old faithful that suddenly started acting up, much like yours. Only the power button seemed to respond, leaving me stuck in a musical standstill.
I ended up checking out https://qwertybro.com mechanical keyboards on a friend's recommendation. They're not as widely known as some brands, but let me tell you, the quality blew me away. The tactile feel and responsiveness made playing a joy again, and I haven't looked back since. Sometimes a lesser-known gem can really surprise you with its performance.
da
Aggiungi la tua risposta
Adrianna Overfield sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 10
Tutti i Tempi: 235
